Good evening everyone,
I’m trying to configure the thermostat with google assistant, and to change the operating modes of the thermostat, but I don’t understand how to do it, I’ll bring you part of the configuration, if anyone can help me.
thanks
/ls
sitemaps
Text label="Riscaldamento" icon="radiator" {
Selection item=FF_Boiler_Modo label="Funzionamento" mappings=[0="Manuale",1="Automatico",2="Presenza",3="Pres+Aut",4="Arieggiare"]
Setpoint item=FF_Boiler_Heating step=1 minValue=10 maxValue=30 icon="heating"
Setpoint item=FF_Boiler_minima step=1 minValue=10 maxValue=30 icon="temperature_cold"
Setpoint item=FF_Boiler_massima step=1 minValue=10 maxValue=30 icon="temperature_hot"
Default item=FF_Boiler_Stato label="Stato Caldaia [%s]" icon="fire"
items
Group g_FF_Boiler_TSTAT "Termostato" { ga="Thermostat" [ thermostatTemperatureRange="10,30", modes = "off = OFF: Arieggiare, heat = COMFORT: Manuale, eco = ECO:Pres+Auto, on = ON:Presenza, auto" ] }
Number FF_Boiler_Heating "Riscaldamento [%.1f °C]" (g_FF_Boiler_TSTAT) {ga="thermostatTemperatureSetpoint"}
Switch FF_Boiler_Stato "Stato Caldaia [%s]" (FF_Boiler) {channel="mqtt:topic:caldaia:stato_caldaia"}
Number FF_Boiler_Modo "Funzionamento" (g_FF_Boiler_TSTAT) { ga="thermostatMode" }
Number FF_Boiler_minima "Temperatura Minima [%.1f °C]" (g_FF_Boiler_TSTAT) { ga="thermostatTemperatureSetpointLow" }
Number FF_Boiler_massima "Temperatura Massima [%.1f °C]" (g_FF_Boiler_TSTAT) { ga="thermostatTemperatureSetpointHigh" }
Number FF_FamilyRoom_Temperature "Temperatura Soggiorno [%.1f °C]" <temperature>(g_FF_Boiler_TSTAT) {channel="mqtt:topic:temperature:temperatura_soggiorno", ga="thermostatTemperatureAmbient"}
Number FF_FamilyRoom_Humidity "Umidità Soggiorno [%.0f %%]" <humidity> (g_FF_Boiler_TSTAT) {channel="mqtt:topic:humidity:umidita_soggiorno", ga="thermostatHumidityAmbient"}
