Hello all,
I was attempting to create a simple thermostat widget:
There are many great widget examples and used them for reference. However, I ran into some difficulty since my thermostat requires a distinct Cool or Heat Setpoint command. The examples I encountered on line only have a single Setpoint item.
String T1_CoolSetpoint "T1 Cool Temp [%s]" <temperature> { channel="serial:serialDevice:Aprilaire:Therm_1:T1_CoolSetpoint"}
String T1_HeatSetpoint "T1 Heat Temp [%s]" <temperature> { channel="serial:serialDevice:Aprilaire:Therm_1:T1_HeatSetpoint"}
String T1_ModeSet "T1 Mode Set" { channel="serial:serialDevice:Aprilaire:Therm_1:T1_ModeSet"}
I would like to be able to incrementally increase / decrease the Setpoint by 1 , and have the widget distinguish between the HVAC mode while assigning the respective Cool or Heat Setpoint. Have tried the configuration bellow and I could get it to work individually for either Cool or Heat, but no success when related to the HVAC mode.
- component: oh-button
action: command
actionCommand: =Number(items['.....?......'].state.split(' ')[0]) + 1
actionItem: "= (items.T10_ModeSet.state === 'COOL') ? 'T10_CoolSetpoint' : 'T10_HeatSetpoint'"
color: blue
icon-f7: plus
iconSize: 30
Any suggestions would be appreciated.
