Let’s say my binding defines a thing action that takes QuantityType<Temperature>
as its arguments. For example:
setHold(QuantityType<Temperature> coolSetPoint, QuantityType<Temperature> heatSetPoint)
In a rule, when I try to define a variable as a QuantityType, LSP flags Temperature
as an error because its type is unknown. I suppose this is because javax.measure.quantity.Temperature
is not injected into the rules engine. And, since I can’t import javax.measure.quantity.Temperature
in my rule, I see no way to resolve the error.
Also, when saving the rule, it complains in the log file.
The method setHold(ThingActions, QuantityType<Object>, QuantityType<Object>) from the type EcobeeActions refers to the missing type Object
Despite all of this, the call to setHold
seems to work.
I’m assuming the issue won’t be fixed in the DSL rules engine, as that rule engine will be deprecated in OH3.
@5iver Do you know how the above will behave in NGRE?
