Thing status not working anymore on ESPHome devices after OH 3.2 update
Since I’ve updated OpenHab to 3.2 my ESPHome Things always show the status as OFFLINE. I’m using this status for some of my rules to check if my ESPHome sensors are booted up correctly. Here is how I’ve configured the availability topic in ESPHome:
mqtt:
  broker: 192.168.1.1
  client_id: mydevice
  discovery: True
  birth_message:
    topic: mydevice/availability
    payload: online
  will_message:
    payload: offline
I’ve also checked if the topic changes to online, but the Thing in OpenHab is always offline. Did anything change since this update regarding the availability of homeassistant devices?
Update:
I just found out that the thing status works again if I remove the thing an re-add it using discovery. But it only works until I restart OpenHab. After the restart the devices stay in offline mode. I also found some errors in the log when OpenHab start’s up:
2022-02-07 22:51:57.541 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
	at org.openhab.binding.mqtt.generic.MqttChannelTypeProvider.derive(MqttChannelTypeProvider.java:132) ~[?:?]
	at org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery.publishResults(HomeAssistantDiscovery.java:204) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
2022-02-07 22:52:26.341 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Duplicate channels mqtt:homeassistant_5ccf7ff03cc4:4ce1d806:5ccf7ff03cc4:ESPbinary_5Fsensorwater_5Falert#sensor
	at org.openhab.core.thing.util.ThingHelper.ensureUniqueChannels(ThingHelper.java:152) ~[?:?]
	at org.openhab.core.thing.util.ThingHelper.ensureUniqueChannels(ThingHelper.java:144) ~[?:?]
	at org.openhab.core.thing.util.ThingHelper.addChannelsToThing(ThingHelper.java:105) ~[?:?]
	at org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler.accept(HomeAssistantThingHandler.java:292) ~[?:?]
	at org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler.accept(HomeAssistantThingHandler.java:1) ~[?:?]
	at org.openhab.binding.mqtt.generic.tools.DelayedBatchProcessing.run(DelayedBatchProcessing.java:110) ~[?:?]
2022-02-07 22:52:30.494 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Duplicate channels mqtt:homeassistant_5ccf7ff03cc4:4ce1d806:5ccf7ff03cc4:5ccf7ff03cc4_2Dwifisignal#sensor
2022-02-08 02:57:52.068 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Duplicate channels mqtt:homeassistant_68c63a94e011:4ce1d806:68c63a94e011:ESPbinary_5Fsensorwater_5Falert#sensor
2022-02-08 02:57:57.875 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
2022-02-08 02:59:52.798 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService                                    ] - Scheduled runnable ended with an exception:
I also have the same problem on a separate OpenHab installation and I just created an issue on GitHub: [mqtt.homeassistant] Thing status of ESPHome devices not working after OH restart. · Issue #12295 · openhab/openhab-addons · GitHub
I’ve just tested this in the latest release 3.3 of OpenHab and this problem still exists on the same mqtt things. Any idea what could be the problem here?
I know this is not a solution but can you try
will_message:
topic: mydevice/availability2
payload: offline
Basically redirect will to diff topic
Currently there is some strange behaviour in esphome after sending online on availability topic one more msg is posted as offline after half sec or so
