- Platform information:
- VM, x64, Intel Xeon
- Ubuntu 18.04
- Java Runtime Environment: zulu-8
- openHAB version: 2.3
Hi there,
I think, I’m lost on this one: I read the new openHAB docs, to set up the shiny, new KNX binding with things and channels. Although Paper UI is possible now, I’d like to edit plain old text files. Therefor I have looked at the doc pages for things and the documentation for the KNX binding - in particular the syntax for a thing syntax definition and examples. But I don’t understand the KNX example for a thing by comparing it to a thing syntax.
Thing definition: Thing <binding_id>:<type_id>:<thing_id> "Label" @ "Location" [ <parameters> ]
Hint: no curly braces, no syntax for channels?
Bridge knx:ip:bridge [
ipAddress="192.168.0.10",
portNumber=3671,
localIp="192.168.0.11",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="0.0.0"
Thing device generic [
address="1.2.3",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : demoSwitch "Light" [ ga="3/0/4+<3/0/5" ]
Type rollershutter : demoRollershutter "Shade" [ upDown="4/3/50+4/3/51", stopMove="4/3/52+4/3/53", position="4/3/54+<4/3/55" ]
Type contact : demoContact "Door" [ ga="1.019:<5/1/2" ]
Type number : demoTemperature "Temperature" [ ga="9.001:<5/0/0" ]
Type dimmer : demoDimmer "Dimmer" [ switch="5/0/0+<5/0/1", position="5/0/2+<5/0/3", increaseDecrease="5/0/4" ]
Type string : demoString "Message" [ ga="5/3/1" ]
Type datetime : demoDatetime "Alarm" [ ga="5/5/42" ]
Hint: curly braces, channels? A “device generic” thing, which - if it is a thing - doesn’t follow the syntax rule for things …
Could somebody point me to the relevant documentation, please.
Very kind regards,
Carsten
