The reconnect attempts are made based on the Refresh Interval you set for the Tibber API within the binding. If the server will not accept, the connect attempt will fail, and will wait next attempt until refresh interval is reached.
Hi there,
Iâm using Tibber-Binding and it works like a charm. Great to control the consumption of my heat pump and BEV. Just one question:
Does anyone have some experience, what might be the best set of rules to heat the water according to the price. Not for the heating the room, but for normal hot water (DHW)?
Is it best to increase the target temperature for DHW from 45° to 60° when price is low? Or to switch DHW to manual/off when price is high? Any suggestions for that?
Thanks in advance.
Cheers, Sebastian
Iâm in the waiting line for Tibber and my API-Token works already.
Using OH3.4.1-release and what Iâm missing is some of the API-functionality like the âpriceLevelâ (CHEAP, NORMAL, EXPENSIVE, âŠ). Do I have to configure something? or is it not present in the binding anymore?
Price level is included as a default channel in the binding, as part of the Tibber subscription query:
All right, Iâm sorry, was real blind!
directing some attention to this, I find the âBestPriceâ-functionality of the aWATTar binding very useful, perhaps it can be merged or used within the Tibber-Binding?
I have a problem with only the item âTibberAPITomorrowPricesâ. It gets no updateâŠ
From âTibber - Bindings | openHABâ the complete âdemo.itemsâ was copied and only the â7cfae492â was updated to my ID.
In the Thing âTibber APIâ i have ALL channel besides âTibberAPITomorrowPricesâ
Does anyone can give me a hint why the most important channel is missing and also the item TibberAPITomorrowPrices is not updatedâŠ
Thanks in advance!
Could you set logging to debug and post the response from Tibber?
Looks like a lot of infomartion is missing in the API response?
Up to now iâm not using the Pulse. Are the price array exclusive to Pulse users?
2023-02-21 22:47:55.432 [DEBUG] [ibber.internal.handler.TibberHandler] - API response: {âdataâ:{âviewerâ:{âhomeâ:{âcurrentSubscriptionâ:{âpriceInfoâ:{âcurrentâ:{âtotalâ:0.3243,âstartsAtâ:â2023-02-21T22:00:00.000+01:00â,âlevelâ:âEXPENSIVEâ}}},âdailyâ:{ânodesâ:[{âfromâ:â2023-02-20T00:00:00.000+01:00â,âtoâ:â2023-02-21T00:00:00.000+01:00â,âcostâ:1.5109073952,âunitPriceâ:0.222127,âconsumptionâ:6.802,âconsumptionUnitâ:âkWhâ}]},âhourlyâ:{ânodesâ:[{âfromâ:â2023-02-21T21:00:00.000+01:00â,âtoâ:â2023-02-21T22:00:00.000+01:00â,âcostâ:null,âunitPriceâ:0.3309985,âconsumptionâ:null,âconsumptionUnitâ:âkWhâ}]}}}}}
As a Tibber customer in Germany waiting for my Pulse to arrive Iâm able to access the future prices via Tibber API explorer:
viewer {
homes {
currentSubscription{
priceInfo{
tomorrow {
total
energy
tax
startsAt
Response:
"data": {
"viewer": {
"homes": [
"currentSubscription": {
"priceInfo": {
"tomorrow": [
"total": 0.2922,
"energy": 0.1399,
"tax": 0.1523,
"startsAt": "2023-02-22T00:00:00.000+01:00"
"total": 0.2787,
"energy": 0.1285,
"tax": 0.1502,
"startsAt": "2023-02-22T01:00:00.000+01:00"
Looks like you have to check the âShow advancedâ box to make the channel for tomorrow prices visible:
Linking an item to âPrices for tomorrow as a JSON arrayâ should do the trick:
> precision rfc3339
> select * from TibberAPI_PricesfortomorrowasaJSONarray
time item value
2023-02-21T22:58:39.766Z TibberAPI_PricesfortomorrowasaJSONarray [{"startsAt":"2023-02-22T00:00:00.000+01:00","total":0.2922},{"startsAt":"2023-02-22T01:00:00.000+01:00","total":0.2787},{"startsAt":"2023-02-22T02:00:00.000+01:00","total":0.2748},{"startsAt":"2023-02-22T03:00:00.000+01:00","total":0.2787},{"startsAt":"2023-02-22T04:00:00.000+01:00","total":0.2799},{"startsAt":"2023-02-22T05:00:00.000+01:00","total":0.2914},{"startsAt":"2023-02-22T06:00:00.000+01:00","total":0.3131},{"startsAt":"2023-02-22T07:00:00.000+01:00","total":0.3317},{"startsAt":"2023-02-22T08:00:00.000+01:00","total":0.3356},{"startsAt":"2023-02-22T09:00:00.000+01:00","total":0.3215},{"startsAt":"2023-02-22T10:00:00.000+01:00","total":0.3072},{"startsAt":"2023-02-22T11:00:00.000+01:00","total":0.2887},{"startsAt":"2023-02-22T12:00:00.000+01:00","total":0.2799},{"startsAt":"2023-02-22T13:00:00.000+01:00","total":0.2794},{"startsAt":"2023-02-22T14:00:00.000+01:00","total":0.2876},{"startsAt":"2023-02-22T15:00:00.000+01:00","total":0.3053},{"startsAt":"2023-02-22T16:00:00.000+01:00","total":0.3125},{"startsAt":"2023-02-22T17:00:00.000+01:00","total":0.3221},{"startsAt":"2023-02-22T18:00:00.000+01:00","total":0.334},{"startsAt":"2023-02-22T19:00:00.000+01:00","total":0.3313},{"startsAt":"2023-02-22T20:00:00.000+01:00","total":0.3186},{"startsAt":"2023-02-22T21:00:00.000+01:00","total":0.309},{"startsAt":"2023-02-22T22:00:00.000+01:00","total":0.3037},{"startsAt":"2023-02-22T23:00:00.000+01:00","total":0.2857}]
2023-02-21T23:00:40.463Z TibberAPI_PricesfortomorrowasaJSONarray []
Please note that the array has been cleared (Iâm in the CET/+01:00 time zone) as the prices for tomorrow arenât available yet.
Ok we have the same setup. Also Germany waiting for the ordered Pulse.
Tibber API explorer responses for tomorrow and today like you showed. No problem on that side.
"data": {
"viewer": {
"homes": [
"priceInfo": {
"today": [
"total": 0.3023,
"energy": 0.1347,
"tax": 0.1676,
"startsAt": "2023-02-23T00:00:00.000+01:00"
"total": 0.2984,
"energy": 0.1314,
"tax": 0.167,
"startsAt": "2023-02-23T01:00:00.000+01:00"
"total": 0.2955,
"energy": 0.129,
"tax": 0.1665,
"startsAt": "2023-02-23T02:00:00.000+01:00"
Unfortunately iâm missing the âShow advancedâ checkbox and donât know why.
So Iâm not able to link an item to it because the channel is missingâŠ
I have it like this defined in the Tibber.items file and both are still âNULLâ.
Also the linking should ideally not be necessary by linking the item and channel in the text file?
String TibberAPITomorrowPrices "Price per hour tomorrow JSON array" {channel="tibber:tibberapi:ab460af:tomorrow_prices"}
String TibberAPITodayPrices "Price per hour today JSON array" {channel="tibber:tibberapi:ab460af:today_prices"}
On a sidenote does anyone know if a Pulse can be bought/operated without Tibber, too?
Or of a different device to provide the same function?
If you created your thing a long time ago from the UI, you might have to delete it, create it again and relink your items.
Iâm afraid not. Each Pulse comes with a unique password, hash and stuff, which is preconfigured with the Tibber API.
You can intercept the communication and practically have both a local interface and send the data to Tibber like this
But from what I discussed with Tibber it ia not possible in Germany to send data without a Pulse or Discovergy for the hourly tariff. There has to be some certified tibber hardware doing that and not API only. Too many possible manipulation possibilities, I guess
this one is from a Swedish seller, but might work for other markets aswell, just a guess I have not tested it.
Let me know if there is something I can help with regarded Swedish.
Br Basse
Sorry, missed the link,
I donât really see a big difference between feeding âoptimizedâ energy consumption data via API and via a transmitter that speaks IEC62056-21, SML, Logarex or Imps ⊠Iâm no laywer, but I think German §248c StGB wouldnât apply, but there is German § 263 StGB âŠ
Summary:
It would be illegal - and keep in mind that a âmoderne Messeinrichtungâ can provide historical data itself.
itâs easy:
requirement:
- use a digital meter (mind the difference from a âsimple eHZâ vs an smart meter!)
- have hourly tariff
- disconnect the certified hardware / never use one; weâre talking about the âTibber Pulseâ, an upgrade to a digital meter, so it behaves -in part- like a smart meter
- start your high load on high tariff hours
- calculate the high load consumption
- substract the hig load from overall consumption
- only send the ânormal consumptionâ via API
- wait for low tariff hours
- add the calculated high load consumption
- add it over the period of time you used the high tariff
I could easily write a rule for that using persistence. piece of cake.
of course itâs illegal. tax fraud is also illegal - and still people do it.
The second reason for an EVU would be to avoid immense support costs for people thinking they can use just whatever script to hourly upload the consumption and then Tibber had to bind valuable ressource to go through âhow to use our API correctlyâ with each and everyoneâŠ
can I get the current grid feed counter of a two-way meter through a Pulse/the Tibber binding, too ?
I only see the consumption and feedin-since-midnight channels.
My Tibber Pulse just arrived today and what I can say for sure is, you can read-out of course current consumption and current feedin (as this is then shown in the App). What Iâm missing (and donât find in the Tibber Developer API docs) is the overall meter reading for consumption (aka 1-0:1.8.0) and feed-in (aka 1-0:2.8.0). Perhaps Iâm missing somethingâŠ?
