Now you got me.
Actually that post was about lastMeterProduction, not lastMeterConsumption.
Iâm experiencing dropouts in the live power data from the Tibber Binding:
Data feed persistence stopped and 22:00 CEST, resumed operation without my intervention at about 02:54 CEST, stopped again at about 09:00 CEST; manual restart of the Tibber Binding via Karaf console at 11:25, persistence and live power channel data stopped again, but Tibber API explorer was providing live measurement data, 2nd manual restart at 14:30 CET âŚ
openhab> bundle:list | grep ibber
279 x Active x 80 x 3.4.0.202212140407 x openHAB Add-ons :: Bundles :: Tibber Binding
openHAB log (nothing at around 22:00 CEST yesterday):
2023-03-31 11:52:11.776 [WARN ] [ibber.internal.handler.TibberHandler] - IO Exception: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@86e67c::DecryptedEndPoint@3ecd3a{l=/192.168.1.181:59660,r=api.tibber.com/52.210.45.21:443,OPEN,fill=-,flush=-,to=60030/0}
2023-03-31 19:56:10.889 [WARN ] [ibber.internal.handler.TibberHandler] - IO Exception: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@1419228::DecryptedEndPoint@ff62c2{l=/192.168.1.181:50044,r=api.tibber.com/99.81.131.250:443,OPEN,fill=-,flush=-,to=60034/0}
2023-04-01 02:51:58.824 [WARN ] [ibber.internal.handler.TibberHandler] - IO Exception: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@dcc3eb::DecryptedEndPoint@1f95775{l=/192.168.1.181:35542,r=api.tibber.com/99.81.131.250:443,OPEN,fill=-,flush=-,to=60008/0}
at org.openhab.binding.tibber.internal.handler.TibberHandler$TibberWebSocketListener.sendMessage(TibberHandler.java:548) ~[?:?]
at org.openhab.binding.tibber.internal.handler.TibberHandler.close(TibberHandler.java:391) ~[?:?]
at org.openhab.binding.tibber.internal.handler.TibberHandler$TibberWebSocketListener.onWebSocketError(TibberHandler.java:466) ~[?:?]
at org.openhab.binding.tibber.internal.handler.TibberHandler.close(TibberHandler.java:399) ~[?:?]
2023-04-01 02:52:45.384 [WARN ] [ibber.internal.handler.TibberHandler] - Websocket Client Stop Exception: java.lang.InterruptedException
2023-04-01 07:50:33.281 [WARN ] [ibber.internal.handler.TibberHandler] - CLOSE FRAME - Failed to stop websocket client: null
2023-04-01 11:24:55.262 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'tibber:tibberapi:f3f7052db4' takes more than 5000ms.
2023-04-01 14:30:34.266 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'tibber:tibberapi:f3f7052db4' takes more than 5000ms.
Not sure how to proceed with troubleshooting - any advise appreciated.
Is
something to worry about?
I stand corrected, sorry. Read myself âProductionâ because I knew âConsumptionâ was already there.
Am I correct that lastMeterConsumption
and lastMeterProduction
are the overall meter reading (German: Zählerstand) for used energy and produced energy (German: 1.8.0 and 2.8.0)? I did not read this long thread but this screenshot leads me in that direction.
(I am thinking about getting a Tibber Pulse, so I cannot checkout myself at the moment.)
At least in Germany, Tibber doesnât seem to cope with negative energy prices: the Tibber API currently does not provide prices for tomorrow - so itâs time to check your automation rules for unexpected behavior if tomorrowâs prices arenât available as expected.
Iâm starting everything I got tomorrow. Just to see what happens. Will be a challenge - as itâll be blue sky sunny and Iâll have to work arouns my PV
âŚ
89.995 SEK/NOK (about 7.6 kEUR) for 6.6 kWh and 129.995 SEK/NOK (about 11 kEUR) for 13.3 kWh
I have a problem with the Tibber binding, hoping that anyone can help me. I set the refresh interval to 1 (Minute), but in the events.log Tibber items are refreshed ecery 3 to 5 ms. I can´t understand this behavior and it seems that my system is slowing down and some other rules are not working anymore.
The refresh interval applies only to the query part of the binding. When you have Tibber Pulse / Live subscription, Pulse sends data every 2 seconds over websocket, so all changes/updates will be read.
Many thxs Stian for this information
thx
Can you adjust the channel descriptions, too ? It ainât âsince midnightâ.
Most of production channels are grouped as channel-type production, with description as linked below, i.e. example either last meter recording, or production since midnight, so Iâm uncertain what is needed updated?
Oh sorry I was referring to the recently bespoken channels lastMeterProduction and lastMeterConsumption. They both represent current values, not accumulated since midnight.
My point above was that most of production channels are grouped as production channel-type, and most of consumption channels are grouped as consumption channel-type. Meaning these channel-types cover both since-midnight values as well as meter values, also as referred to in the github extract shown above, having description âŚe.g. last meter reading, accumulated since midnight) with the different examples (since-midnight vs meter) separated by comma.
Frankly Iâm a bit confused. I was looking to get the current power value from the Tibber binding
and thought it was live_lastMeterConsumption
Itâs a single value. The channel description for that is still talking about consumption within a time interval and itâs of Number:Energy
type.
But that does not make sense for a live power value. Channel/item would need to be of Number:Power
type and would be an actual live value in W, not a counter/meter in kWh or some such.
I think both of those (data type and desc) are correct for the live_accumulatedConsumption
channel and there was a copyân paste error in applying that to live_lastMeterConsumption
wdyt?
Ok, I think I was wrong here. Itâs two meter values (which I donât understand the difference of) but Power:Energy und hence the channel description are ok then.
But whatâs the channel Iâm looking for to get current feed-in or grid consumption ?
Is it any of the last 3 channels Iâm looking for ? live_powerProduction
? But what do min and max mean then ? Thereâs only ever one current value.
Naming and descriptions are confusing. Itâs unclear what Tibber means by those.
(itâs news to me they âproduceâ any power actually but assume this is when you have a PV to produce hence feed-in more than your home consumes).
live_averagePower
, live_min_
and live_max_
the description says itâs about energy consumed/produced in some interval but theyâre of Number:Power
type so that does not make sense to me. If itâs about min/max/avg within some interval, whereâs that interval defined ?
Dazed and confused.
I only have consumption in my setup, so I do not have any clarifying answers to your production questions. The Tibber binding is set up using the official Tibber API docs, and each channel is described here (under LiveMeasurement):
https://developer.tibber.com/docs/reference
I cannot see the channel today_prices using OH 4.0.0 M5 (it was also the case with the latest 3.x release). Tomorrow_prices is available. Any hints?
