I have looked around in the forum and google around to get some information about, how is the format or syntax for [%1$H:%1$tM]. I understand H and M stand for Hour and minutes, but what is %1$ ?
and how do I translate Time cron “0 0 6 * * ? *”
Why these 2 different format.
I understand how Boolean works, but how are there written in openhab. I see some && !=
Is there any place here in openhab.org, that already have explained this?
As you can you can see I not a programmer of any kind, but I’m slowly getting better as I go on.
This request has must like most likely been posted in a wrong section, but it was the best I could find.
Sorry for that.
Because the two have nothing to do with each other. Time cron "0 0 6 * * ? *" is a Rule trigger and it tells the Rule engine to trigger the Rule at 06:00 every day. [%1$H:%1$tM] is how you format how a DateTime Item appears on your sitemap. A DateTime Item is a specific moment in time.
All the usual operators are supported. See below for the docs that describe them.
Yes. See Rules | openHAB and don’t neglect to click on the links.
