I am new to openHAB and trying to learn how to write rules. Ive started with this time of day rule
(Code at very top of page).
I have basicaly installed the astro binding, and copy / paste the items file and rules file.
how ever im logging this error
13:31:56.663 [ERROR] [untime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Calculate time of day state': Invalid format: "NULL"
This is my items file
/* Groups */
Group All
Group Lights "All Lights [(%d)]" (All)
Group IndoorLights "Indoor Lights [(%d)]" (All)
Group OutdoorLights "Outdoor Lights [(%d)]" (All)
Group SecurityLights "Security Lights [(%d)]" (All)
Group NightLights "Night Lights [(%d)]" (All)
Group Configuration "Configuration" <settings> (Status)
Group Status "Status" (Configuration)
Group Atsro <sun_clouds> (Configuration)
/* Config Items */
Switch VacationMode "Vacation Mode" <vacation> (Configuration)
Switch NightSwitch "Night Switch" (Configuration) ["Switchable"]
Switch Christmas "Christmas Lights" (Configuration)
/* Virtual Switches */
String SecurityLightBackyardLeftSelect (Status)
/* Astro */
DateTime Current_DateTime "Today [%1$tA, %1$td.%1$tm.%1$tY]" <clock> (Astro) {channel="ntp:ntp:local:dateTime"}
String vTimeOfDay "Current Time of Day [MAP(weather.map):%s]" <tod> (Astro)
DateTime vMorning_Time "Morning [%1$tH:%1$tM]" <sunrise> (Astro)
DateTime vSunrise_Time "Day [%1$tH:%1$tM]" <sun> (Astro) { channel="astro:sun:home:rise#start" }
DateTime vSunset_Time "Evening [%1$tH:%1$tM]" <sunset> (Astro) { channel="astro:sun:home:set#start" }
DateTime vNight_Time "Night [%1$tH:%1$tM]" <moon> (Astro)
DateTime vBed_Time "Bed [%1$tH:%1$tM]" <bedroom_blue> (Astro)
DateTime vEvening_Time "Afternoon [ %1$tH:%1$tM]" <sunset> (Astro) { channel="astro:sun:minus90:set#start" }
/* Wall SwitchPlates */
Switch WsPatioRelay1 "Relay 1" (Lights) ["switchable"] {channel="mqtt:topic:b6d9115a:Relay1"}
Switch WsPatioSwitchShort1 "Switch short 1" (Status) {channel="mqtt:topic:b6d9115a:SwitchShort1"}
Switch WsPatioSwitchLong1 "Switch long 1" (Status) {channel="mqtt:topic:b6d9115a:SwitchLong1"}
Switch WsKitchenRelay1 "Relay 1" (Lights) {channel="mqtt:topic:0a52d8c3:Relay1"}
Switch WsKitchenSwitchShort1 "Switch short 1" (Status) {channel="mqtt:topic:0a52d8c3:SwitchShort1"}
Switch WsKitchenSwitchLong1 "Switch long 1" (Status) {channel="mqtt:topic:0a52d8c3:SwitchLong1"}
Switch WsKitchenRelay2 "Relay 2" (Lights) ["switchable"] {channel="mqtt:topic:0a52d8c3:Relay2"}
Switch WsKitchenSwitchShort2 "Switch short 2" (Status) {channel="mqtt:topic:0a52d8c3:SwitchShort2"}
Switch WsKitchenSwitchLong2 "Switch long 2" (Status) {channel="mqtt:topic:0a52d8c3:SwitchLong2"}
/* Security Lights */
Switch SecurityLightBackyardLeft "Security light backyard (left)" (Lights) ["switchable"] {channel="mqtt:topic:846b6b01:SecurityLight_BackyardLeft"}
/* Lifx Lighting */
Color LightKitchen1Color "Kitchen Light 1 Color" <colorlight> (Lights) ["lighting"] {channel="lifx:colorlight:D073D55410F1:color"}
Switch KitchenLightSwitch (Lights) {channel="lifx:colorlight:D073D55410F1:color"}
Dimmer LightKitchen1Temperature "Kitchen Light 1 Temperature" <light> (Lights) {channel="lifx:colorlight:D073D55410F1:temperature"}
Number LightKitchen1Signalstrength "Kitchen Light 1 Signal strength" <qualityofservice> {channel="lifx:colorlight:D073D55410F1:signalstrength"}
Color LightDiningRoom1Color "Dining Room Light 1 Color" <colorlight> (Lights) ["lighting"] {channel="lifx:colorlight:D073D553DC9F:color"}
Dimmer LightDiningRoom1Temperature "Dining Room Light 1 Temperature" <light> (Lights) {channel="lifx:colorlight:D073D553DC9F:temperature"}
Number LightDiningRoom1Signalstrength "Dining Room Light 1 Signal strength" <qualityofservice> {channel="lifx:colorlight:D073D553DC9F:signalstrength"}
Color LightLivingRoom1Color "Living Room Light 1 Color" <colorlight> (Lights) ["lighting"] {channel="lifx:colorlight:D073D555AFEB:color"}
Dimmer LightLivingRoom1Temperature "Living Room Light 1 Temperature" <light> (Lights) {channel="lifx:colorlight:D073D555AFEB:temperature"}
Number LightLivingRoom1Signalstrength "Living Room Light 1 Signal strength" <qualityofservice> {channel="lifx:colorlight:D073D555AFEB:signalstrength"}
And this is my Rule
val logName = "Time Of Day"
rule "Calculate time of day state"
System started or // run at system start in case the time changed when OH was offline
Channel 'astro:sun:home:rise#event' triggered START or
Channel 'astro:sun:home:set#event' triggered START or
Channel 'astro:sun:minus90:set#event' triggered START or
Time cron "0 1 0 * * ? *" or // one minute after midnight so give Astro time to calculate the new day's times
Time cron "0 0 6 * * ? *" or
Time cron "0 0 23 * * ? *"
logInfo(logName, "Calculating time of day...")
// Calculate the times for the static tods and populate the associated Items
// Update when changing static times
// Jump to tomorrow and subtract to avoid problems at the change over to/from DST
val morning_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(18)
vMorning_Time.postUpdate(morning_start.toString)
val night_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(1)
vNight_Time.postUpdate(night_start.toString)
val bed_start = now.withTimeAtStartOfDay
vBed_Time.postUpdate(bed_start.toString)
// Convert the Astro Items to Joda DateTime
val day_start = new DateTime(vSunrise_Time.state.toString)
val evening_start = new DateTime(vSunset_Time.state.toString)
val afternoon_start = new DateTime(vEvening_Time.state.toString)
// Calculate the current time of day
var curr = "UNKNOWN"
switch now {
case now.isAfter(morning_start) && now.isBefore(day_start): curr = "MORNING"
case now.isAfter(day_start) && now.isBefore(afternoon_start): curr = "DAY"
case now.isAfter(afternoon_start) && now.isBefore(evening_start): curr = "AFTERNOON"
case now.isAfter(evening_start) && now.isBefore(night_start): curr = "EVENING"
case now.isAfter(night_start): curr = "NIGHT"
case now.isAfter(bed_start) && now.isBefore(morning_start): curr = "BED"
// Publish the current state
logInfo(logName, "Calculated time of day is " + curr)
vTimeOfDay.sendCommand(curr)
// Examples for use of vTimeOfDay
rule "Day time started"
Item vTimeOfDay changed to "DAY" // does not work prior to OH 2.3 Release
// do stuff when DAY starts
//rule "Some rule"
//when
// some trigger
//then
// if(vTimeOfDay.state != "BED") return;
// do stuff to do when it isn't BED time
//end
As i said i am new and try to get my head around how it all works
any help would be appreaceated
