Maybe a little example will help:
My rollershutter should closed between 11:00am and 1:00pm. The rest of the day it is controlled manually.
So you must set shutter on (equal down) from 11:00am to 1:00pm - blue.
The rest ist grey with red line.
Now you can drive the shutter as you like and the shutter stay in this position.
At 11:00am the shutter will be drive down and at 1:00pm he drived in the position befor 11:00am.
When you not used the manual mode the rest of the day is grey (without red underline).
At each switch point, every 15min, the shutter will be drive up. It’s not possible to close the shutter manual from 5:00pm to 6:00pm. Each 15min he will drive up.
The namespace:
event = connected state or states in the timeline, left and right limit manual (grey with red line)
restore state = the state befor the left limit will be stored and after finishing event he will be retored
It’s not nessesary to change the rule file, it’s works fine, as describt below.
