See the first post. Spezified is mo- fr and sa-su not mo-th. Alternative one can set each day allone.
Hi Chod,
for sure can I share my timeLinePicker settings.
Iâm using it for heating function in my living area, bathrooms and office. Therefore I have four different Transferitems active.
I can show you an example of the livingroom.
my Groups:
Group gTimepicker
Group gTimepickerObserver
Items for TimePicker rule:
String TransferItem1 â[%s]â (gTimepicker)
String TransferItem2 â[%s]â (gTimepicker)
String TransferItem3 â[%s]â (gTimepicker)
String TransferItem4 â[%s]â (gTimepicker)
Items for TimePicker Livingarea:
//TimePicker Wohnbereich
Switch vUrlaubTP âUrlaubsmodusâ
String vWohnbereichTP âWohnbereichâ
String vWohnbereichState
Number Temp_Wohnbereich_Kom âKomfort [%.1f °C]â <temperature_hot>
Number Temp_Wohnbereich_Spar âStandard [%.1f °C]â
Number Temp_Wohnbereich_Nacht âNacht [%.1f °C]â <temperature_cold>
timeLinePicker.rules (config part only, nothing else was changed):
// -------------------- part of config -----------------------------------------------------------------------
val HashMap<String,ArrayList> timePicker = newHashMap(
âTransferItem1â â newArrayList(âvWohnbereichStateâ),
âTransferItem2â â newArrayList(âvBadEGStateâ),
âTransferItem3â â newArrayList(âvBueroStateâ),
âTransferItem4â â newArrayList(âvBadOGStateâ)
//âTransferItem2â â newArrayList(âThermostat1â,âThermostat2â)
// -------------------- end of config ------------------------------------------------------------------------
wohnbereichTimeLinePicker.rules:
rule âHeizung Wohnzimmerâ
Item vWohnbereichState changed
var Number nacht = 0
var Number standard = 0
var Number komfort = 0
nacht=(Temp_Wohnbereich_Nacht.state as DecimalType)
standard=(Temp_Wohnbereich_Spar.state as DecimalType)
komfort=(Temp_Wohnbereich_Kom.state as DecimalType)
if (vUrlaubTP.state == OFF){
// deactivate all sprinckler zones
//switch ((vWohnbereichState.type).toString) {
switch (vWohnbereichState.state) {
case âNachtâ : {
// activate Nacht
logInfo(âHeizung Wohnbereichâ,âNachtmodusâ)
HeizungWohnzimmerSetpoint.sendCommand(nacht.toString)
HeizungEsszimmer.sendCommand(nacht.toString)
HeizungKueche.sendCommand(nacht.toString)
case âStandardâ : {
// activate Standard
logInfo(âHeizung Wohnbereichâ,âStandardmodusâ)
HeizungWohnzimmerSetpoint.sendCommand(standard.toString)
HeizungEsszimmer.sendCommand(standard.toString)
HeizungKueche.sendCommand(standard.toString)
case âKomfortâ : {
// activate Komfort
logInfo(âHeizung Wohnbereichâ,âKomfortmodusâ)
HeizungWohnzimmerSetpoint.sendCommand(komfort.toString)
HeizungEsszimmer.sendCommand(komfort.toString)
HeizungKueche.sendCommand(komfort.toString)
else {
logInfo(âHeizung Wohnbereichâ,âUrlaubsmodusâ)
timeLinePicker.sitemap:
Frame label=âHeizplĂ€neâ {
Text item=vWohnbereichTP {
Frame label=âHeizung Wohnbereichâ {
Setpoint item=Temp_Wohnbereich_Kom minValue=15 maxValue=28 step=0.5
Setpoint item=Temp_Wohnbereich_Spar minValue=15 maxValue=28 step=0.5
Setpoint item=Temp_Wohnbereich_Nacht minValue=15 maxValue=28 step=0.5
Switch item=vUrlaubTP
Frame label=âTime Picker Wohnbereichâ {
Webview url=âhttp://192.168.x.xx:8080/static/time-line-picker/index.html?ip=192.168.x.xx:8080&transferItem=TransferItem1&states=Nacht,Standard,Komfort&yAxisLabel=1,2,3,4,5,6,7&event=no&dark=noâ icon=âcalendarâ height=14
@tose thanks for this incredible feature
i have implemented it and it works as defined.
the configuration could be simplified.
i want to turn off at 8:00 AM (even itâs already turned OFF )and and turn on at 8:00 PM (even itâs already turned ON)
I would expect to make as below this but the event parameter restore the previous state correct me if am wrong
is it possible to implement it on this way?
@nakh_Home Itâs nice to hear that you can use the widget.
Is it your intention that the device is turned ON at 8:00PM and additional you want to switch off manuell after this switch point ?
This use case is not possible. The base switch condition in the event configuration is OFF. So itâs possible to define inside a timerange the device is OFFand you can turn it ON. However if you define ON and you switched manuell to OFF, the device is automaticaly turned ON .
If I understand you correct, you only want switch points. Without restoreing the previous state.
Even if one toggled the state the timeline picker will switching at the next switch point.
I think this is possible but is it realy good? The most of time the state is undefined.
You have well understood me.
Instead of range, I prefer to program events at a specific time
Okay. I will need a little bit free time and i will look.
In this context i will also look to improve the administration of the widget.
Then there are three possibilities:
- static conditions
- static conditions witch additional event (but event means, manuell events)
- switch point conditions
I guess you could have a virtual switch between the timeline switcher and the manual switch and give priority in your rule to implement this
I do understand the requested functionality from @nakh_Home, however I believe it should not be (directly) build into the timeline picker.
The present functionality does check every 15 minutes if the desired state is set and commands a change if not. Such periodic check isnât needed in the desired functionality, a check for each stored switch time would be enough!
Using the timeline picker UI for setting these switch times creates a limitation, because actually a switch time is only possible every 15 minutes. Decreasing this time would increase the period checks for the present functionality.
To conclude, I would not put that functionality into this timeline picker. Such switch times could more easily be created by something like a âtaskerâ .
I have one question:
For what is âgTimepickerObserverâ used? It is not in the documentation but in the items file and in the rules file. It looks like it has something to do with event parameter.
Yes, this group is for restoreing in the event mode. It is only nessessary to create this group in the item file, no further configuration. The intention is a secure state restoring after an reboot.
Edit: Iâm looked at the code again. This Group is used to determine if an event for the cuurent item occured.
Timeline picker to setup heating, light and so on - #149 by tose
- static conditions
i am quite struggling to update the rules in order to program events at a specific time.
Please could you guide me
@Chod, not sure to understand
Please show me the webview url with all parameters.
You know, the rule is updated all 15 minutes?
You must wait a little bit after an update the timepline.
Webview url="http://192.168.1.150:8080/static/time-line-picker/index.html?ip=192.168.1.150:8080&transferItem=TransferItemDummyEvent&yAxisLabel=7,1,2,3,4,5,6&lang=en&event=yes&dark=yes" height=14
NP, ON, will turn on , OFF will turn OFF and manuel nothing
Many thanks to the OP author for sharing its work! I am using it and it works as expected in my local network: the only problem is that the widget does not appear through the openhab website
https://home.myopenhab.org
Is it a known limitation, or is there some setting that I have to set?
@Lionello_Marrelli Yes the limition is known. Itâs the CORS policy of the browser.
There are middleware e.g. express server that works as middleware and can set the flag Access-Control-Allow-Origin. But i mean a additional server for remote access is too much.
A possible solution is a VPN- Connection. Then it will be working.
@nakh_Home The many amp; is only through copy&past? Correct, in the original sitemap is this wrong.
What is NP ?
Manuell means you can control the item and the scheduler will not updating the state at the next switch point (each 15min)
Not a problem
Yes, it works with VPN.
I found one problem:
Frame label="heating Example" {
Webview url="http://ip-addr-openHAB/static/time-line-picker/index.html?ip=xx.xx.xx.xx:8080&transferItem=TransferItem1&yAxisLabel=1,2,3,4,5,6,7" height=14
The IP-Address cannot be localhost if you use sitemap from a different computer. It must be the real IP-Address of the OH-Server. Looks like the js.scripts are running locally not on the OH-host.
Itâs not a issue. The timelinepicker works with an Webview element, it is a separat page. This page is served from your OH server.
But the logic works as javascript on your local maschine. So itâs not possible to use localhost. You must specify the ip- address.
Hello @tose good afternoon,
Thank you for sharing your fantastic work. There are many use cases on my house that I can take advantage from this TimeLinePicker. It is really straightforward to put in operation and intergrates very well with the system.
Perfect!
Two questions please.
- Is it possible to set periods less than 15 minutes? Does it require alot of work to change?
- I would like to add a language to the switchPointSet.js file. Iam not used to deal with javascript but I decided to give it a shot. After editing the required part and loading the file it seems that the old file is mantained and not the new one.
Could you please give me a hand on these subjects?
Thank you in advanced fo your work.
Best regards.
