To use the expire binding you must create a switch item. If creating an item is already over your head, I’ll post link to learn. When the switch is triggered, however long you have configured it to run,then the stuff you coded in happens
Aside from the machine you have installed OH on, what is controlling the light- on what protocol?
Some protocols and devices allow to set timers to OFF in secs or millisecs also on the light-switch-controller side itself, relieving your OH machine of 1 rule(no biggie anyhow, but might be cleaner, while you get your grips with OH)
Hi Andrew, you seem knowledgeable with the Expire Binding.
Do you know if I can use the REST API to add Expire settings to my switch items?
I don’t have an .items file to edit, because I created all my switch items using PaperUI.
I’m using OpenHAB 2.5.2 on Raspberry Pi 4.
Delete Items from PaperUI, then recreate as Items in an xxx.items file. The only method I know. You’d also re-add any other channel links in the .items file, that you made careful note of before deletion.
Don’t mix PaperUI and files management of any one given Item or Thing, although you can mix styles within your system e.g. link a “file” Item to a “PaperUI” Thing/channel.
