I noticed that when updating a rule, I get exceptions because of stale timers (created with createTimer). I unsuccesfully attempted to prevent these exceptions:
- Make a rule for “System shuts down” and cancel the timer. The rule is not triggered.
- Adding NULL checks on the items in the rule, since I get a “java.lang.NullPointerException: null” in my log. That also does not work.
The exception is:
2020-10-23 11:48:23.922 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 12 2020-10-23T11:47:53.512+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@720d8edc (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@3f5c40eb (conditionalExpression: false)
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
<etc>
2020-10-23 11:48:23.925 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 12 2020-10-23T11:47:53.512+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
Caused by: java.lang.NullPointerException
<etc>
It is just a minor thing, but I would like to keep the log free of these exceptions.
Can it be done? Any suggestions?
