Timer Nullpointer
I want to get an alarm if a window is open for more then 20 minutes.
I created the following rule for this:
var Timer bo_fenster_Timer = null
rule "Fenster OG Bad 20 Min. offen"
        Item bo_fenster changed
        if ( bo_fenster.state==CLOSED ) {
            if ( bo_fenster_Timer!== null ) {
                bo_fenster_Timer.cancel
                bo_fenster_Timer=null
        else if ( bo_fenster.state==OPEN ) {
            if ( bo_fenster_Timer===null)  {
                bo_fenster_Timer=createTimer(now.plusMinutes(20)) [|
                    logInfo("Rules", "Fenster DG Bad 20 Min. offen")
But when i save the rule file i will get a Nullpointer exception in the openhab.log after some seconds
2018-11-06 08:52:18.631 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ā€˜test.rules’
2018-11-06 08:52:28.632 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ā€˜test.rules’
2018-11-06 09:02:07.313 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2018-11-06T09:02:07.300+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1f86ee8
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.(ScriptError.java:66) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:132) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:759) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:225) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:457) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy195.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
2018-11-06 09:02:07.323 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2018-11-06T09:02:07.300+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
Caused by: java.lang.NullPointerException
at org.eclipse.smarthome.model.script.engine.ScriptError.(ScriptError.java:66) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:132) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:759) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:225) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:457) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy195.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
… 1 more
I don’t see any hint in the excpetion whats going wrong.
Does somebody have the same problem or know a solution for thist?
I’m running on the following system:
  • Platform information:
    • Hardware: Raspberry Pi 3+
    • OS: Raspbian GNU/Linux 9 (stretch)
    • Java Runtime Environment: openjdk version ā€œ1.8.0_181ā€
    • openHAB version: 2.3.0 (4.1.5)
Best regards
Eric
Try that:
            bo_fenster_Timer=createTimer(now.plusMinutes(20), [ |
I changed the rule like Vincent said.
Now the Nullpointer i posted before is gone but after the rule fired (i also see the log after 20 minutes) i get a other Nullpointer…
2018-11-06 10:04:16.853 [INFO ] [eclipse.smarthome.model.script.Rules] - Fenster DG Bad 20 Min. offen
2018-11-06 10:07:47.169 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2018-11-06T10:07:47.152+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@177c1e4
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.getDefaultObjectValue(XbaseInterpreter.java:779) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:462) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
2018-11-06 10:07:47.182 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2018-11-06T10:07:47.152+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.getDefaultObjectValue(XbaseInterpreter.java:779) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:462) ~[?:?]
… 1 more
            bo_fenster_Timer.cancel()
I changed the .cancel to .cancel().
The Window is still open since the first rule execution. (no state change)
But i still get the same exception after some time.
The rule looks now like this:
3 x ā€œ=ā€ ?
and that should be only != null
I would do the following:
  1. add more logging to determine at which line of code the error occurs
  2. reduce the amount of time from 20 minutes to 20 (or less )seconds so that I could quickly test the code
Also, why do you have ā€œ===ā€ instead of ā€œ==ā€ on line 12?
Looking at my own code that uses timers I use NULL for comparison rather than null, I don’t know if the case makes any difference.
I’ve found that if I change code (and save it) that has already set a timer then I’ll get an error in the log when the timer from the previous version of the code triggers. Subsequent timers triggered from the new code execute correctly. You should be able to test if this is the happening for you by reducing the length of the timer from 20 minutes to a few seconds.
One more thing, do you see any syntax errors output in openhab.log when you save the rule?
@holgerw, @higgers
When comparing for the java null you have to use ===
When comparing for the openHAB itemState NULL then you use ==
Yes it does, see above. null and NULL are two very different things
ok, i am on openhab v. 1.83, i know only == and != from 1.x wiki.
Interesting, I use:
if(timerTmp != NULL) {
in my code and it works as I had expected on my 2.3 installation.
@higgers
timerTmp will ALWAYS be different than NULL because it’s a Timer type and cannot have NULL openHAB state
Now it timerTmp was an openHAB item, it could have the state NULL but you would have to use:
if (timerTmp.state != NULL) {
Are you sure you have pasted in the exact rule you’re using, with no parts cut out? Is there a different rule that might be producing the exception?
The only thing I can think of is a race condition between the bo_fenster_Timer!== null test and the bo_fenster_Timer.cancel() method call. Try rewriting it to:
    if (bo_fenster.state == CLOSED) {
        bo_fenster_Timer?.cancel()
    } else if (bo_fenster.state == OPEN) {
        if (bo_fenster_Timer === null) {
            bo_fenster_Timer = createTimer(now.plusMinutes(20)) [
I fear you may be chasing a red herring, and your error comes from a different Timer. This one cannot both fail and then produce its logInfo message.
There is an important trap with Timers when you are editing .rules fles. When a rule file is reloaded, any Timers already running continue to run. But they are ā€˜orphaned’ from the context of the rule that spawned them. They invariably fail with an error.
How to produce an error;
Start a 20 min timer from a rule.
Edit the rule file, reload after 10 mins.
Observe the error 10 mins later.
There’s no fix for this other than being aware, it’s a consequence of in-flight modification.
Rosko57 described that far better than I did in my first post above :slight_smile:
@rossko57, @higgers that was the trick.
I moved the rule to a own .rule file and after this the exception didn’t appeared again.
@vzorglub thanks for the help with the rule syntax.
I will now move the rule back in my other rule file and hope that there are no other problems ^^
Thanks for the fast help.
