Hi all, want to share one new solution, how to use obtain and display current trains timetable. I used 2 services: DB API and KVV API, but this method could be easily used for other systems. I have 2 displays in our home - primary neat the door and second one for clients, my wife has small Nails-studio, so this display helps clients to orient in local trams. Currently she is banned from work due to lockdown, so decided to implement this old idea.
- Architecture: python script → MQTT bus → OpenHAB items
- DB APi is public and also could be used to display trams overall Germany, i used local KVV API just for interest.
Also, maybe this could be an example, how to implement connection to some random remote API.
So, first - you need to obtain API keys.
- DB: just register at https://developer.deutschebahn.com/ and you can start to use API with nice test UI.
- KVV: they also provide some API: KVV - Karlsruher Verkehrsverbund - Bahn und Bus - Open Data , but you need to register there. I am too lazy, my way is simplier - go to live.kvv.de and take it’s key.
Then, you need to find your train station to display.
- DB: Use API to find station directly in developer console page.
- KVV station ID could be parsed from URL on live.kvv.de page.
Then, use this scripts:
- DB: kvv-timetable.py
- KVV: kvv-timetable.py
Check built-in help for arguments. Both scripts are pretty simple: check API and place parsed values as MQTT topic:
# Publish routes to MQTT
publish.single(args.mqtt_topic+'/route-'+str(idx), payload=payload, qos=0, retain=True, hostname=args.mqtt_host,
port=int(args.mqtt_port), client_id="KVV-Routes", auth=mqtt_auth)
Then, just define MQTT-driven generic things (4 routes):
Thing mqtt:topic:openhab:kvv_timetable "KVV Timetable" (mqtt:broker:openhab) {
Channels:
Type string : r0_route [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.route"]
Type string : r0_dst [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.destination_city"]
Type string : r0_time_str [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.time"]
Type datetime : r0_time [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.tms"]
Type string : r0_summary_text [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.summary_text"]
Type string : r0_dir_text [stateTopic="kvv-timetable/route-0", transformationPattern="JSONPATH:$.direction_text"]
Type string : r1_route [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.route"]
Type string : r1_dst [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.destination_city"]
Type string : r1_time_str [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.time"]
Type datetime : r1_time [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.tms"]
Type string : r1_summary_text [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.summary_text"]
Type string : r1_dir_text [stateTopic="kvv-timetable/route-1", transformationPattern="JSONPATH:$.direction_text"]
Type string : r2_route [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.route"]
Type string : r2_dst [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.destination_city"]
Type string : r2_time_str [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.time"]
Type datetime : r2_time [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.tms"]
Type string : r2_summary_text [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.summary_text"]
Type string : r2_dir_text [stateTopic="kvv-timetable/route-2", transformationPattern="JSONPATH:$.direction_text"]
Type string : r3_route [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.route"]
Type string : r3_dst [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.destination_city"]
Type string : r3_time_str [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.time"]
Type datetime : r3_time [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.tms"]
Type string : r3_summary_text [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.summary_text"]
Type string : r3_dir_text [stateTopic="kvv-timetable/route-3", transformationPattern="JSONPATH:$.direction_text"]
And items:
// This file defines Railroad and other time-table information
String timetable_0_route { channel="mqtt:topic:openhab:kvv_timetable:r0_route" }
String timetable_0_dst { channel="mqtt:topic:openhab:kvv_timetable:r0_dst" }
String timetable_0_summary_text { channel="mqtt:topic:openhab:kvv_timetable:r0_summary_text" }
DateTime timetable_0_time { channel="mqtt:topic:openhab:kvv_timetable:r0_time" }
String timetable_0_time_str { channel="mqtt:topic:openhab:kvv_timetable:r0_time_str" }
String timetable_0_dir_text { channel="mqtt:topic:openhab:kvv_timetable:r0_dir_text" }
String timetable_1_route { channel="mqtt:topic:openhab:kvv_timetable:r1_route" }
String timetable_1_dst { channel="mqtt:topic:openhab:kvv_timetable:r1_dst" }
String timetable_1_summary_text { channel="mqtt:topic:openhab:kvv_timetable:r1_summary_text" }
DateTime timetable_1_time { channel="mqtt:topic:openhab:kvv_timetable:r1_time" }
String timetable_1_time_str { channel="mqtt:topic:openhab:kvv_timetable:r1_time_str" }
String timetable_1_dir_text { channel="mqtt:topic:openhab:kvv_timetable:r1_dir_text" }
String timetable_2_route { channel="mqtt:topic:openhab:kvv_timetable:r2_route" }
String timetable_2_dst { channel="mqtt:topic:openhab:kvv_timetable:r2_dst" }
String timetable_2_summary_text { channel="mqtt:topic:openhab:kvv_timetable:r2_summary_text" }
DateTime timetable_2_time { channel="mqtt:topic:openhab:kvv_timetable:r2_time" }
String timetable_2_time_str { channel="mqtt:topic:openhab:kvv_timetable:r2_time_str" }
String timetable_2_dir_text { channel="mqtt:topic:openhab:kvv_timetable:r2_dir_text" }
String timetable_3_route { channel="mqtt:topic:openhab:kvv_timetable:r3_route" }
String timetable_3_dst { channel="mqtt:topic:openhab:kvv_timetable:r3_dst" }
String timetable_3_summary_text { channel="mqtt:topic:openhab:kvv_timetable:r3_summary_text" }
DateTime timetable_3_time { channel="mqtt:topic:openhab:kvv_timetable:r3_time" }
String timetable_3_time_str { channel="mqtt:topic:openhab:kvv_timetable:r3_time_str" }
String timetable_3_dir_text { channel="mqtt:topic:openhab:kvv_timetable:r3_dir_text" }
That’s all! Now setup systemd service to run this script(s) every minute and items will be updated in realtime. For display, you can simple add them to sitemap (summary_text channel):
Group item=timetable_0_summary_text label="Trains" icon="calendar" {
Frame label="KVV" {
Text item=timetable_0_summary_text label="" icon="calendar"
Text item=timetable_1_summary_text label="" icon="calendar"
Text item=timetable_2_summary_text label="" icon="calendar"
Text item=timetable_3_summary_text label="" icon="calendar"
Frame label="Deutsche Bahn" {
Text item=timetable_db_0_summary_text label="" icon="calendar"
Text item=timetable_db_1_summary_text label="" icon="calendar"
Text item=timetable_db_2_summary_text label="" icon="calendar"
Text item=timetable_db_3_summary_text label="" icon="calendar"
And as Habpanel item:
<table cellpadding="3" width="100%">
<tr>
<td>
<table cellpadding="3" width="100%" class="timetable timetable-kvv">
<tr>
<td width="10%">
{{ itemValue('timetable_0_route') }}
</td>
<td width="60%" align="left">
{{ itemValue('timetable_0_dst') }}
</td>
<td width="30%">
{{ itemValue('timetable_0_time_str') }}
</td>
</tr>
<tr>
<td>
{{ itemValue('timetable_1_route') }}
</td>
<td align="left">
{{ itemValue('timetable_1_dst') }}
</td>
<td>
{{ itemValue('timetable_1_time_str') }}
</td>
</tr>
<tr>
<td width="10%">
{{ itemValue('timetable_2_route') }}
</td>
{{ itemValue('timetable_2_dst') }}
</td>
<td width="30%">
{{ itemValue('timetable_2_time_str') }}
</td>
</tr>
<tr>
<td>
{{ itemValue('timetable_3_route') }}
</td>
<td align="left">
{{ itemValue('timetable_3_dst') }}
</td>
<td>
{{ itemValue('timetable_3_time_str') }}
</td>
</tr>
</table>
</td>
</tr>
</table>
That’s all! Very simple and usefull. Some additional pics, how it looks like in reality:
