When I turn them on, they show as “on” in the GUI, so fine, so good, but when I use the “turn all Lights off” button, they go to “off” in the GUI, but are not really turned off.
Distance to the remote antenna too far?
I have that problem with one Tinkerforge remote device: it goes to on when switched on but doesn’t turn off when switched off.
When I move it closer to the 433 Mhz antenna it works fine …
there are no changes merged to the binding since 1.7.1. If it really doesn’t load it’s probably an issue of the “runtime-snapshot” or your configuration.
Sorry for the delay. I will check Remote Switch behavior today.
If the current state is busy, the Bricklet is currently sending a code to switch a socket. It will not accept any calls of switchSocket() until the state changes to ready.
I have no quick fix for that, I have to think about a good solution.
Could you please open an issue.
Nope, no changes. I don’t know, you have maybe overseen this:
From my log file, it looks like the tinker forge module doesn’t even get started when I start openhab. There is no entry at all. I can however run all commands using the brickv software.
[quote=“andre1, post:13, topic:3007, full:true”]
From my log file, it looks like the tinker forge module doesn’t even get started when I start openhab.[/quote]
Because the Tinkerforge binding is running fine here on my setup you should look for a problem on your hardware or configuration.
Maybe you could post your openhab.cfg so we can take a look if it is only a misconfiguration …
Edit: @theo already mentioned the upper/lower case problem in your config …
[quote=“andre1, post:15, topic:3007, full:true”]
It’s weird that i don’t see anything related to tinker forge in the log file, not even a “loaded” on any error on loading it.[/quote]
You should have something like 2015-11-21 20:05:19.360 [INFO ] [.service.AbstractActiveService] - Tinkerforge Refresh Service has been started
in your log.
GUI, but are not really turned off.[/quote]
Although I don’t use the “all lights off” feature I’ve set this up to test it and I can confirm your perception with the 1.8.0 snapshot from cloudbees: I used two lights, one turns off, one does not turn off, in the GUI they all show up as off.
Then I used @theo 's fixed binding from his post above and I can confirm with that binding everything is running fine with “all lights off” through your group function: both lights turned off, both lights showed as off in the GUI.
