Im looking for an smart enough AC Motor speed control. My plan is to use it for ventilation in my home. Features that i would like are:
Remote start/stop
Remote set speed/set point
230 VAC for the motor.
Protocol is not important aslong as it integrates with openhab =)
It need to be a proper speedcontroller not just a dimmer (that chops the waveform).
I have been searching around some but not found anything.
Please tell me when you find a solution to this. I bought a cheap chinese made ventilation heat exchanger some months ago, but have not found a good solution to control the fan.
The closest I have found is Qubino - ZMNHSD1 (https://www.tronika.no/no/lysstyring/961-dimmer-zmnhsd1.html) that supports a 100W mono-phase asynchronous motor, my fan motor max out at 123W. I think this would work on my setup with some extra cooling fins, but this is only a guess, I have not had the time to test.
I ended up using 3x Z-wave 230VAC ON/OFF switches to get 0,1,2 & 3 speed settings on my 165W 230VAC fan.
0 - OFF - when away from home
1 - just moving, air rush barly noticeable. No motor noise.
2 - motion detector 10min trigger. About 1/3 of full speed.
3 - humidity > 50% (showering) Full speed.
If you want full control without the regulating noise of a dimmer, you need a much more costly frequency converter, which you probably end up programming to 2 or 3 speeds anyway.
If any dimmers can do it, my bet is on the Fibaro Dimmer 2.
It does a load analysis after power is applied.
If that is still too noisy, frequency converter is the way to go for full speed control. Many of them have a 0-10V input that can be connected to a Qubino 0-10V dimmer.
For more discussions head over to FB group ‘Smarthus & IoT Norge’. https://www.facebook.com/groups/smarthusnorge/
I think ill look for a frequency converter. I have a lov voltage dimmer that i didnt use for another project. Im not to keen on fibaro, they were tested by our electrical safety department here in sweden and it was a mayor failure - firehazard.
Norskan er akurat inge problem. Dere må icke snacke så fort bare.
I just recently exchanged the fan in my Heat Exchanger, that got noisy as I forgot to switch off the exhaust while the crew was polishing plasters.
And i have that unit right in front of me 230V 0-10V control.
When you dont kill it the fan is really quiet and outputs >600 m3/h
For the the 0-10V output from OH2 you can use Tinkerforge bricklet that does have a binding.
