Toilet air freshener idea
Hi I put together a simple device using a
Tuya ZigBee smart fingerbot (search on AliExpress)
And a Sonoff ZigBee dongle
I 3d printed a support to hold the perfume bottle and fingerbot.
The perfume is from Zara home so if you need the 3d model let me know. The fingerbot came with some stickers and some little wooden blocks which I used.
In openhab I already had a rule that turned on a light using a DSC alarm motion detector. So I added a function to activate the fingerbot if there was someone in the room for more than 5 minutes (I didn’t want it spraying every time someone went in eg. just to look in the mirror).
The only problem I had was the dongle interferes with a rfxcom usb transceiver. Openhabian loses the connection to the rfxcom and seems to overwrite the driver. So I had to move the dongle to a separate home assistant server and use ZigBee2mqtt.
It works perfectly, I will probably add some rules for timed sprays if we are home during the day.
Overall investment about £40 but the dongle will be used for other devices too. Happy wife too!
Ohh this is nifty! Nice thinking :slight_smile: I have the mind to make something similar but based on already existing solutions. This video is in Portuguese unfortunately but it’s easy enough to follow if you care.
You can add alternative parts like this:
Add a battery inside and you have a stand alone solution that doesn’t look out of place :slight_smile:
But your solution with oob things is great!
Great idea - but: isn’t the fingerbot you linked to a Bluetooth device?
Yes sorry I bought off AliExpress but couldn’t find a way to link from the app. I got a tuya ZigBee smart fingerbot plus and the associated tools although you don’t really need them.
I bought the same Tuya fingerbot and I am using a Raspbee II with deCONZ.
I am able to see the fingerbot as a light in the deCONZ.
After that, I can create a thing in OpenHab, only as battery.
However, it is not possible to change its state from Openhab.
I tried to change the DDF as reported here: https://github.com/dresden-elektronik/deconz-rest-plugin/issues/7094
but the situation does not change.
my last DDF is the following:
  "schema": "devcap1.schema.json",
  "manufacturername": ["_TZ3210_dse8ogfy", "_TZ3210_j4pdtz9v"],
  "modelid": ["TS0001", "TS0001"],
  "vendor": "Tuya",
  "product": "Fingerbot",
  "sleeper": false,
  "status": "Gold",
  "subdevices": [
      "type": "$TYPE_ON_OFF_OUTPUT",
      "restapi": "/lights",
      "uuid": [
        "$address.ext",
        "0x01"
      "items": [
          "name": "attr/id"
          "name": "attr/lastannounced"
          "name": "attr/lastseen"
          "name": "attr/manufacturername"
          "name": "attr/modelid"
          "name": "attr/name"
          "name": "attr/swversion",
          "parse": {"fn": "zcl:attr", "ep": 1, "cl": "0x0000", "at": "0x0001", "script": "tuya_swversion.js"},
          "read": {"fn": "zcl:attr", "ep": 1, "cl": "0x0000", "at": "0x0001"}
          "name": "attr/type"
          "name": "attr/uniqueid"
          "name": "state/on",
          "parse": {"fn": "tuya", "dpid": 1, "eval": "Item.val = Attr.val;" },
          "write": {"fn": "tuya", "dpid": 1, "dt": "0x10", "eval": "Item.val == 1 ? 1 : 0;"},
          "read": {"fn": "tuya"}
          "name": "config/tuya_unlock"
          "name": "state/reachable"
      "type": "$TYPE_BATTERY_SENSOR",
      "restapi": "/sensors",
      "uuid": [
        "$address.ext",
        "0x01",
        "0x0001"
      "meta": {
        "values": {
          "config/mode": {"clic": 0, "switch": 1, "program": 2}
      "items": [
          "name": "attr/id"
          "name": "attr/name"
          "name": "attr/type"
          "name": "config/on"
          "name": "config/reachable"
          "name": "config/mode",
          "values": [
              ["clic", 0], ["switch", 1], ["program", 2]
          "parse": {"fn": "tuya", "dpid": 101, "eval": "if (Attr.val == 0) { Item.val = 'clic' } else if (Attr.val == 1) { Item.val = 'switch' } else { Item.val = 'program' }"},
          "write": {"fn": "tuya", "dpid": 101, "dt": "0x30", "eval": "if (Item.val == 'clic') { 0 } else if (Item.val == 'switch') { 1 } else { 3 }"},
          "read": {"fn": "none"}
          "name": "state/battery",
          "parse": {"fn": "tuya", "dpid": 105, "eval": "Item.val = Attr.val;" },
          "read": {"fn": "none"},
          "default": 0
          "name":"config/delay",
          "read":{
            "fn":"none"
          "write":{
            "dpid":103,
            "dt":"0x2b",
            "eval":"Item.val;",
            "fn":"tuya"
          "parse":{
            "dpid":103,
            "eval":"Item.val = Attr.val;",
            "fn":"tuya"
          "default":1
          "name": "state/lastupdated"
any suggestion on where to look for the issue or a workaround?
Thanks a lot.
Great idea Julian. May it be possible to get your 3d printing file? :slight_smile:
I already have the fingerbot.
Would be great, thxxx :slight_smile:
I have used zigbee2mqtt which has full support of the fingerbot (and lots of other low cost tuya.
My perfumer fingerbot unfortunately died. The motor on the fingerbot was not strong enough, the spray nozzle on the bottle started to become quite hard to press. Maybe someone can find a better type of bottle…
Here is the STL file I had to change the extension to .pdf otherwise I couldn’t upload. Just change it back to .STL and it should work.
perfumer.pdf (4.2 KB)
hello,
in order to control the fingerbot, I am moving my whole setup from deconz to zigbee2mqtt (quite challenging, but step after step I am making it).
Could you share how you configure this item in order to send a command to the fingerbot?
I can see that this device sends a mqtt messages to the Broker, but I am not able to send a message back to the device and let him change his state.
UID: mqtt:topic:fingerbot
label: Fingerbot mqtt
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:4ff7832a04
channels:
  - id: fingerbot_switch
    channelTypeUID: mqtt:switch
    label: Fingerbot Switch
    description: ""
    configuration:
      commandTopic: zigbee2mqtt/fingerbot/set
      stateTopic: zigbee2mqtt/fingerbot/switch
      off: off
      on: on
Exploring openHAB is a rewarding journey. I’ve found that engaging with the documentation and using showcases really boosts understanding. Contributing on GitHub keeps things engaging and insightful. For home safety, especially with automations involving candles, check out https://nothingbutscents.com/blogs/product-guides-tips/candle-self-extinguish-safety . Safety at home is crucial, and these tips have been great for making my smart home safer. Stay curious and keep experimenting!
