Yeh, sorry about that, but I have a work in progress calculating cost.
Here in Norway we have hourly spot prices throughout the day forecasted by NordPool a day in advance.
I have made a scraper for that data, but haven’t finished it all yet, so I snipped out the part you got, but might have forgot to remove a line or two.
The other items you didn’t get was indeed those cost items.
Since I haven’t figured out how to make arrays of items, I ended up doing this:
Number nextDay23_24 (nextDayHourlyPrices)
Number nextDay24_01 (nextDayHourlyPrices)
Number nextDay01_02 (nextDayHourlyPrices)
Number nextDay02_03 (nextDayHourlyPrices)
Number nextDay03_04 (nextDayHourlyPrices)
Number nextDay04_05 (nextDayHourlyPrices)
Number nextDay05_06 (nextDayHourlyPrices)
Number nextDay06_07 (nextDayHourlyPrices)
Number nextDay07_08 (nextDayHourlyPrices)
Number nextDay08_09 (nextDayHourlyPrices)
Number nextDay09_10 (nextDayHourlyPrices)
Number nextDay10_11 (nextDayHourlyPrices)
Number nextDay11_12 (nextDayHourlyPrices)
Number nextDay12_13 (nextDayHourlyPrices)
Number nextDay13_14 (nextDayHourlyPrices)
Number nextDay14_15 (nextDayHourlyPrices)
Number nextDay15_16 (nextDayHourlyPrices)
Number nextDay16_17 (nextDayHourlyPrices)
Number nextDay17_18 (nextDayHourlyPrices)
Number nextDay18_19 (nextDayHourlyPrices)
Number nextDay19_20 (nextDayHourlyPrices)
Number nextDay20_21 (nextDayHourlyPrices)
Number nextDay21_22 (nextDayHourlyPrices)
Number nextDay22_23 (nextDayHourlyPrices)
Number toDay23_24 (toDayHourlyPrices)
Number toDay24_01 (toDayHourlyPrices)
Number toDay01_02 (toDayHourlyPrices)
Number toDay02_03 (toDayHourlyPrices)
Number toDay03_04 (toDayHourlyPrices)
Number toDay04_05 (toDayHourlyPrices)
Number toDay05_06 (toDayHourlyPrices)
Number toDay06_07 (toDayHourlyPrices)
Number toDay07_08 (toDayHourlyPrices)
Number toDay08_09 (toDayHourlyPrices)
Number toDay09_10 (toDayHourlyPrices)
Number toDay10_11 (toDayHourlyPrices)
Number toDay11_12 (toDayHourlyPrices)
Number toDay12_13 (toDayHourlyPrices)
Number toDay13_14 (toDayHourlyPrices)
Number toDay14_15 (toDayHourlyPrices)
Number toDay15_16 (toDayHourlyPrices)
Number toDay16_17 (toDayHourlyPrices)
Number toDay17_18 (toDayHourlyPrices)
Number toDay18_19 (toDayHourlyPrices)
Number toDay19_20 (toDayHourlyPrices)
Number toDay20_21 (toDayHourlyPrices)
Number toDay21_22 (toDayHourlyPrices)
Number toDay22_23 (toDayHourlyPrices)
and in the JSS rule:
function calcHourlyConsumptionCost(hourlyConsumption) {
// fetch NordPool hourly price for this hour interval
switch (today.getHours()) {
case 0:
hourlyPrice = parseFloat(items.getItem("toDay24_01").state)
break
case 1:
hourlyPrice = parseFloat(items.getItem("toDay01_02").state)
break
case 2:
hourlyPrice = parseFloat(items.getItem("toDay02_03").state)
break
case 3:
hourlyPrice = parseFloat(items.getItem("toDay03_04").state)
break
case 4:
hourlyPrice = parseFloat(items.getItem("toDay04_05").state)
break
case 5:
hourlyPrice = parseFloat(items.getItem("toDay05_06").state)
break
case 6:
hourlyPrice = parseFloat(items.getItem("toDay06_07").state)
break
case 7:
hourlyPrice = parseFloat(items.getItem("toDay07_08").state)
break
case 8:
hourlyPrice = parseFloat(items.getItem("toDay08_09").state)
break
case 9:
hourlyPrice = parseFloat(items.getItem("toDay09_10").state)
break
case 10:
hourlyPrice = parseFloat(items.getItem("toDay10_11").state)
break
case 11:
hourlyPrice = parseFloat(items.getItem("toDay11_12").state)
break
case 12:
hourlyPrice = parseFloat(items.getItem("toDay12_13").state)
break
case 13:
hourlyPrice = parseFloat(items.getItem("toDay13_14").state)
break
case 14:
hourlyPrice = parseFloat(items.getItem("toDay14_15").state)
break
case 15:
hourlyPrice = parseFloat(items.getItem("toDay15_16").state)
break
case 16:
hourlyPrice = parseFloat(items.getItem("toDay16_17").state)
break
case 17:
hourlyPrice = parseFloat(items.getItem("toDay17_18").state)
break
case 18:
hourlyPrice = parseFloat(items.getItem("toDay18_19").state)
break
case 19:
hourlyPrice = parseFloat(items.getItem("toDay19_20").state)
break
case 20:
hourlyPrice = parseFloat(items.getItem("toDay20_21").state)
break
case 21:
hourlyPrice = parseFloat(items.getItem("toDay21_22").state)
break
case 22:
hourlyPrice = parseFloat(items.getItem("toDay22_23").state)
break
case 23:
hourlyPrice = parseFloat(items.getItem("toDay23_24").state)
break
default:
hourlyPrice = 0.0
break
console.log("hourlyPrice=(NOK) " + (hourlyPrice*hourlyConsumption)/1000)
one last question, my energy meter gives me info in kw and not in kWH. i would like to add just a “/ 100” to keep units in kWH but with right values. i think i just need to add “/ 100” to minute consumption (and all other values will be automatically okay), but i cannot find the line where to add it.
can you point me to the right direction?
and if possibile, to have all values with max 3 decimal numbers like 0.323 kWH.
If it’s the same power meter you posted a few posts up, the instantaneous power consumption is in W.
If you want to do calculations in kW instead, you need to divide by 1000. (k=kilo=1000)
Power and energy is not the same beast. In order to get the energy consumed, you must look at the power consumed over time, and that time is usually an hour.
That is why my script samples the power every 1s and calculates the energy used per minute.
Power meters rarely supplies samples more often that that.
So
var instPower = parseInt(items.getItem("TpLinkFrigorifero_Power").state, 10)/1000
gives you the power consumption in kW, and keeping the script as is kWmin. (add up 60 of those for an hour)
You might consider changing the item names, since when you now do historical data lookup, you will get a mix of Wmin and kWmin.
When you say you want 3 digit float precision I assume you mean in the sitemap? Use %.3f as below.
Text item=kWHhourlyConsumption label="Last hour [%.3f kWh]"
i also added the state description in metadata as “%.3f kWh” so all items are shown with 3 digit and measurement unit both in sitemap and also in items list.
but i see these errors in the log, and i can’t understand them:
2022-01-11 09:56:53.200 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.id.core.openhab.org/}UUIDResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:67) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:279) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:829) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:550) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:915) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:987) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:285) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.close(HttpOutput.java:638) ~[bundleFile:9.4.43.v20210629]
at org.apache.cxf.transport.http.AbstractHTTPDestination$WrappedOutputStream.close(AbstractHTTPDestination.java:791) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:56) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination$BackChannelConduit.close(AbstractHTTPDestination.java:722) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:63) ~[bundleFile:3.4.5]
... 48 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:182) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:130) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:493) ~[?:?]
at java.nio.channels.SocketChannel.write(SocketChannel.java:507) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:273) ~[bundleFile:9.4.43.v20210629]
... 48 more
2022-01-11 09:56:53.214 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
org.eclipse.jetty.io.EofException: null
... 63 more
here there is the rule adapted:
var today = new Date
var instPower = parseInt(items.getItem("TpLinkFrigorifero_Power").state, 10) /1000
var kwMinute
var hasTickedMinutes
if (isNaN(kwMinute)) {
console.log("Rule starting");
kwMinute = 0;
kWhour = 0;
hasTickedMinutes = false
function isMinuteTick () {
return (today.getSeconds() == 0)
function isHourTick () {
return ((today.getMinutes() == 0) && (today.getSeconds() == 4)) // delay a bit so that the last persisted value becomes part of the sum
if (isMinuteTick()) {
if (!hasTickedMinutes) { // sample a full interval
hasTickedMinutes = true
} else {
kwMinute /= 60
//console.log("kWmin= " + kwMinute);
items.getItem("Frigorifero_kWhMinuto").postUpdate(kwMinute)
kwMinute = 0
} else {
kwMinute += instPower
if (isHourTick()) {
var kwPeriod = items.getItem("Frigorifero_kWhMinuto").history.sumSince(new Date(new Date().setHours(new Date().getHours()-1))) / 60
console.log("kWh = " + kwPeriod);
items.getItem("Frigorifero_kWhOra").postUpdate(kwPeriod)
var now = new Date();
var tday = new Date(now.getFullYear(), now.getMonth(), now.getDate());
var lastMonday = new Date(tday.setDate(tday.getDate()-(today.getDay() + 6) % 7));
var dayStimato = items.getItem("Frigorifero_kWhMinuto").history.sumSince(new Date(new Date().setHours(0, 0, 0))) / 60 // from midnight
var weekStimato = items.getItem("Frigorifero_kWhMinuto").history.sumSince(lastMonday) / 60 // from midnight monday
var monthStimato = items.getItem("Frigorifero_kWhMinuto").history.sumSince(new Date(new Date().setDate(1))) / 60 // from the 1. of the month
var yearStimato = items.getItem("Frigorifero_kWhMinuto").history.sumSince(new Date(new Date().setMonth(0, 1))) / 60 // from 1. january
items.getItem("Frigorifero_kWhGiornoStimato").postUpdate(dayStimato)
items.getItem("Frigorifero_kWhSettimanaStimato").postUpdate(weekStimato)
items.getItem("Frigorifero_kWhMeseStimato").postUpdate(monthStimato)
items.getItem("Frigorifero_kWhAnnoStimato").postUpdate(yearStimato)
anyway, thanks a lot for your script, is really useful and i think i will use it soooo much!
Looks like you have done the exact thing I have set out to do, so very grateful for all the things you have shared here.
I’m hoping to bother you on a sligthly off topic issue. Since you’re in Norway you are probably connecting to the HAN port of your meter(?). Can I ask what HW your using? I optimistically went with the EVA meter reader, but can’t really connect it to my conbee.
Welcome to the forum!
I was an early adopter and have had this up and running since it became available and hence had to do the job myself. (but just recently have I started trying to use the instantaneous power consumption to something useful
I’m using this: METERBUS : PW001G Mbus Slave Level Converter which I doctored to give me TTL level standard serial signal which I connected to an Arduino with a Eth shield. Decoded that data myself, and have a process on my machine listening for new values. Only changes are sent, and re-posted to OH3 via the REST API.
HI OMR, i copied your code but i think there is a problem with the kWHhourlyConsumption. For example if I have 60’s values of kWHminuteConsumption like 220 (Wh) ,kWHhourlyConsumption return value is like 1.10(kWh)…
I’ll post back when I have fixed it, if you haven’t already.
I just compared my values with the readings in the electricity company’s app, and the values matches quite closely. In fact my 1s polling records +200kWh so far this year. They must be cutting me some slack somehow …?
