So recently I hooked up my OpenHAB Raspberry Pi I hadn’t been using in about a year and some (I was mainly using it to control TV related tasks via CEC, but the TV died and the replacement I ended up with months later as a stop gap has no CEC abilities, along with other issues, so was no reason to use OpenHAB until I got other hardware again, which I do now).
At first I had an issue where addons were automatically uninstalling themselves and even after restoring from a backup image of the last good build it was still doing it. So I decided to run the updater, but that broke a myriad of other things too. So I just copied all the config files for Items, Rules, Things, and Sitemap and do a fresh install of OpenHABIAN 2.4.0-1 from the latest image and reinstall all the plugins. This seems to work now, but the HS100 switch I had for the TP-Link Binding no longer seems to function. I use this to control a fan in my room. The switch does show in the Paper UI in the inbox, but i’d rather have it setup via the config files. As far as I can tell from the documentation on the site for the binding, nothing has changed in the way it needs to be setup, but whenever I try to control it, nothing happens and Karaf returns with.
17:35:12.491 [INFO ] [.rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/Fan’ for the unknown item ‘Fan’.
17:35:15.827 [INFO ] [.rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/Fan’ for the unknown item ‘Fan’.
Below are the current lines used in the Things and Items configs.
Things
//TP-Link HS100
Thing tplinksmarthome:hs100:FAN “Fan” [ ipAddress=“XXX.XXX.XXX.XXX”, refresh=60 ]
Items
//TP-Link HS100
Switch FAN “Fan” [ “Switchable” ] { channel=“tplinksmarthome:hs100:FAN:switch” }
Any help would be much appreciated.
