Try placing the device physical closer to your wifi acces point and see if that makes a difference.If that fixes it, it could mean something is interfering with your hs103.
Once added the following was displayed within openHAB.
Status: UNKNOWN
And then it changes to the following.
Status: OFFLINE
**COMMUNICATION_ERROR**
No route to host (Host unreachable)
Please note that the Kasa iOS app can control the HS103 (LOCAL ONLY)
I then changed the power strip it was plugged into and it “SEEMED” to start working again BUT each time I turned on or off the HS103 I would cause a COMMUNICATION_ERROR which lasted for a few seconds.
Here is output from the events.log file.
2022-08-24 12:46:30.420 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'bedroomlamp' changed from UNDEF to ON
2022-08-24 12:46:45.994 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'bedroomlamp' received command OFF
2022-08-24 12:46:45.996 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'bedroomlamp' predicted to become OFF
2022-08-24 12:46:46.002 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'bedroomlamp' changed from ON to OFF
2022-08-24 12:46:50.333 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tplinksmarthome:hs103:xxxxxx' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Read timed out
2022-08-24 12:46:50.338 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'bedroomlamp' changed from OFF to UNDEF
2022-08-24 12:47:00.379 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tplinksmarthome:hs103:xxxxxx' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2022-08-24 12:47:00.382 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'bedroomlamp' changed from UNDEF to OFF
