TP-Link Kasa very slow to update
Openhab 5.2.3 docker on Unraid 7.3.1
About 2 days ago, kasa binding started to be slow on event update. If I use openhab to open/close something, it’s instant. But if I press the physical button on the wall, the update can take 30 secondes or more. Thing is, it’s random. It can work no problem for hours and then stop for 5-10 minutes.
If I check in the kasa and tapo app, I do see the switch updated to ON, but the event itself in openhab take time
It seems to have started when I updated from 5.2.1 to 5.2.3 two days ago. I did install bluelink at the sametime but I tried removing it and it didn’t solved the problem.
I restart both wifi AP and switch, the router, the unraid server, the docker, nothing fixed it.
I’m using nodered to fire rules based on openhab like switching a light when another is switched and right now, sometime it work, sometime it doesn’t.
I’ve enable trace logging for the kasa (TP-Link) binding, nothing, no error or anything. The update is each 1 sec interval.
I’m checked my network, I even stopped all local services I run beside DNS and it didn’t change anything.
I don’t know what to do next. The log doesn’t help since there’s no error, it just seems to take it’s time to pool although it’s suppose to pool each 1 sec.
