TP-Link Outdoor Dimmer Plug (KP405) support
It appears support for this device is not yet available in the tp-link binding
What is required to add support?
This pr to getting merged: [tplinksmarthome] Added new devices ES20, KP125, KP405 and KS230 by Hilbrand · Pull Request #11771 · openhab/openhab-addons · GitHub
(Assuming the dimmer function works, as it’s a feature not available in earlier plugs. I assumed it works the same as switch device with dimmer)
I will test it as soon as it’s in the apt snapshot repo
@hilbrand
The pull is still open. Is there a problem with it? It seems that it will not be merged for 3.2
@hilbrand
I updated to the latest snapshot and the KP405 device was discovered.
It had one SWITCH channel, not a Dimmer Chanel.
The switch channel toggles the plug between 0% and 100% but dimming is not available
Can you update the binding?
I’ve updated the binding. I’ve added a marketplace entry, so it can be installed directly from openHAB main UI: TP-Link Smarthome binding (Beta) [2.5.0;3.6.0)
