this morning I found a Problem on my openhab system due to a restart of my router.
I’m using openhab 3.1 and openhab 3.2 M3 on two pi’s. First is the live, 2nd the testsystem.
On both I have installed the tr064 binding. I used this for a presence detection for my heating.
On both sytems this setup runs for weeks.So the Setup should be ok.
Last week my Fritzbox restarted due to a Softwareupdate to Version 7.29. But also after this update it works.
Actually I saw this ErrorMessage:
17:50:08.982 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:51:08.991 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:52:08.998 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:53:07.646 [DEBUG] [ndar.internal.ICalendarHandlerFactory] - bundle org.openhab.binding.icalendar:3.2.0.M3 (265)[org.openhab.binding.icalendar.internal.ICalendarHandlerFactory(275)] : Querying state active
17:53:07.653 [DEBUG] [.Tr064DynamicStateDescriptionProvider] - bundle org.openhab.binding.tr064:3.2.0.M3 (275)[org.openhab.binding.tr064.internal.Tr064DynamicStateDescriptionProvider(309)] : Querying state active
17:53:07.654 [DEBUG] [nal.phonebook.PhonebookProfileFactory] - bundle org.openhab.binding.tr064:3.2.0.M3 (275)[org.openhab.binding.tr064.internal.phonebook.PhonebookProfileFactory(311)] : Querying state active
17:53:07.656 [DEBUG] [064.internal.Tr064ChannelTypeProvider] - bundle org.openhab.binding.tr064:3.2.0.M3 (275)[org.openhab.binding.tr064.internal.Tr064ChannelTypeProvider(308)] : Querying state active
17:53:07.658 [DEBUG] [ng.tr064.internal.Tr064HandlerFactory] - bundle org.openhab.binding.tr064:3.2.0.M3 (275)[org.openhab.binding.tr064.internal.Tr064HandlerFactory(310)] : Querying state active
17:53:09.004 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:53:53.315 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from OFFLINE (COMMUNICATION_ERROR): could not get device definitions from 192.168.178.1 to UNINITIALIZED
17:53:53.339 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
17:54:02.545 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from UNINITIALIZED (DISABLED) to INITIALIZING
17:54:02.554 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from INITIALIZING to UNKNOWN
17:54:04.634 [DEBUG] [nding.tr064.internal.Tr064RootHandler] - endpointBaseURL is now 'https://192.168.178.1:49443'
17:54:04.650 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: java.net.ConnectException: Verbindungsaufbau abgelehnt
17:55:04.652 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:55:04.658 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tr064:fritzbox:f299e0ff11' changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: java.net.ConnectException: Verbindungsaufbau abgelehnt to OFFLINE (COMMUNICATION_ERROR): could not get device definitions from 192.168.178.1
17:56:04.660 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:57:04.670 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
17:58:04.681 [DEBUG] [nhab.binding.tr064.internal.util.Util] - HTTP Failed to GET uri 'https://192.168.178.1:49443/tr64desc.xml': java.net.ConnectException: Verbindungsaufbau abgelehnt
So, for me it looks that the fritzbox did not accept the credentials any more.
What I tried.
-Create a new User on the Fritzbox. Same settings compared to the one which it was running for a long time
- removed the binding an reinstall it again.
- Check all settings on the fritzbox and on openhab.
Still ending in the same Errormessage.
Also setting the debug level of the binding to Max, I saw no additional infos.
So does someone has an idea?
