Some power banks have momentary voltage interruptions when they lose power, which would make them unreliable for UPS purposes. You can test for it, but I find it hard to trust them.
You can get a UPS with a USB port and then use Network UPS Tools to monitor it. This enables you to also power your modem/router so that openHAB can send you a notification, but if you buy a small one then you’ll only get a few minutes of operation before NUT has to shut it down. Meanwhile, a large UPS takes up more space and can get expensive in a hurry.
I recently came across a few mini UPS devices like this one and this one on Amazon, and I’m intrigued. It makes a ton of sense to just have 5V/9V/12V outputs and not waste energy converting back and forth between AC and DC. However, the 5V USB ports on the ones I linked to only output 2A, and the recommendation for an RPi 3/4 is a 3A power supply. I’m not ready to buy a mini UPS, but I’m keeping an eye out for improvements.
I had the issue with broken sd-cards some time ago also, but found out that since a while (do not know exactly the release) it’s pretty easy to run a raspi with USB-ssd-drives. Since I do this, not problem any more. Just followed this advices (unfortunately in German, but I´m sure you find something in other languages as well, as this is common since a while): Raspberry Pi: Externe USB-Platte/USB-Stick
Regarding USV: I run an old Eaton-Server-USV, which I bought used pretty cheap from ebay and exchanged the battery. Even it’s an old one with reduced capacity, it can run the raspi and the switches and routers for days… NUT´s handles the management and there is even a binding for OH.
Openhabian gives you several well tested tools to significantly improve stability of the system, namely zram, SD sync and autobackup.
In addition to that, in my experience, a standard ups is also important.
I used a usb powerbank with my raspberry pi 3 v2 and it worked well, even if very rarely some problem occurred. I noticed that the raspberry was reporting some undervolt event, and therefore I ended up connecting the original power supply to a standard ups. (The same does not occur for a pi0w, which requires much less power.)
Zram improved reliability a lot, even though you have to pay attention to situations in which log files size grow and fill all available memory.
I am using a high endurance SD card, specifically designed for continuous writes.
I am using the SD sync feature made available by Openhabian and periodically swap the main SD and the backup one. In this way it is possible to test if the backup SD works while still having a valid SD.
I found useful to test all of the backup and restore features on a separate raspberry in order to let the production system work.
Finally, let your family notice when your system works : usually they tend to emphasize when it fails but never pay attention when it works smoothly.
thx for the link - but this seems more difficult / hand made than the option in the openhab-config tool “Move the system root from the SD card to a USB device” – this is the same, no? I had this running under OH 2.5 with an external SSD already, but somewhere I read that I cant run ZRam then anymore, is this correct?
to be honest, i´m actually a bit surprised, that this is possible within the config-tool at all ;-))
I run the usb-ssd since a while and when i managed to get this running, it was not possible to use openhabian-config for this feature.
Ive used ZRAM before and had some issues at this time, so I decided to go this way as the best way for me. maybe it’s worth to rethink today, but you know: Never change a running system.
Don’t discount the value in this though. Even if it only lasts a couple of minutes, the ability to safely shutdown the RPi before power is gone is huge when it comes to protecting your file system.
The purpose of ZRAM is to minimize the number of writes to the SD card. There is a limited number of writes that flash memory can support before it stops working. If you’ve moved to operate off of an external HDD or an SDD (which has it’s own built in mitigations for wear out) there is no longer much benefit to running ZRAM. So it’s not that you can’t run ZRAM, it’s that there really is no benefit in doing so.
Absolutely. I’ve actually got an APC 600VA UPS on the way from Amazon, because my CyberPower ST625U’s battery is no longer reliable after 3+ years and I can’t find a replacement cell for it.
Is this still correct, when openhabian-config itself offer this possibility? I’ve seen this statement already in the past, but with the actual NVRAM of the raspi´s it’s a boot-drive like all others.
100% agree. AND: Running a low-power-device like a raspi give you usually much more than a “few minutes”.
also agree, that was earlier one of the reasons I do not even tried it (as far I can remember).
Of course. The docs say so, and they’re pretty explicit. Didn’t you read them ? Availability of a function whatsoever doesn’t mean anything.
It does not mean that’s supported let alone that it’s a good idea to do.
That’s what it has been ever. (note I assume you refer to the “move root to USB” function, have you ever (recently) tried that ? Then you will have gone through a series of warnings).
(sigh) No. The boot drive is never just a drive “like all others”. openHABian expects the boot drive to be the SD. Various reliability functions such as mirroring, zram and backups are adversely affected when you start messing with that.
For reference, pretty much all to be said about it is said here:
I can look into it. I’ve currently have it scripted through Ansible. But there are so many variables involved I’m not sure it’s possible to script through openHABian in a generic manner.
Is the UPS plugged in to the RPi’s USB or is it subscribed remotely? What model of UPS is being used (the configuration can be different based on the model and there’s this long table of UPS model mapping to the correct NUT driver to use). How long to wait before shutting down? Is this the NUT master primary (i.e. last to shut itself down) or a slave secondary (NUT hasn’t changed to more appropriate terminology yet NUT has changed the terminology after all).
If we make extreme restrictions it might just be possible (e.g. only support locally controlled UPS, force the users to go research to find the right driver themselves, etc.).
NUT really is a disappointing in its complexity.
Of course I don’t really have a test platform at the moment. Are RPi’s still really hard to get these days? Yes, for what they are going for on Amazon I could get a NUC.
With my limited unix skills I had the idea to just get a used UPS that can run my Pi and some other servers for some time, install a second Pi not connected to the UPS, and set up a cron job to ping this Pi every 3 min or so, and if its unavailable due to outage shutdown my openhab Pi.
Not really a great solution, but it would do the job;
Seems an overly complex set up. If the UPS supports NUT (which is a big if), you can set up the RPi to get an alert when the power is lost and it’s running on battery and shut itself down. Even if the UPS doesn’t support NUT, it often will have it’s own software that does the same thing.
UPS batteries are generally good for 3-5 years, so if you get a used one then you may just be buying a nearly dead battery. A new, low-end UPS with a USB port will cost you somewhere between $60-100, which is worthwhile to protect your RPi and other servers.
I also have next-to-no Linux experience, which is why I wrote the beginner’s guide I linked to earlier. It was half to help others, and half to help me do it again in the future.
If the goal is only to help new openHABian users get NUT working, then I think it would be enough to have a default configuration of a standalone, locally controlled UPS. Perhaps there could be some fill-in options in a config popup:
For anything more advanced, the user could make their own changes after the installation.
I’d also suggest making this change in the default monitor settings to account for CyberPower. I don’t think it would negatively impact any other devices. Alternatively, it could be a fill-in field in a popup.
I was surprised to see that someone has revived NUT and put out a new release in April. Hopefully they’ll reduce the complexity in future updates.
