I am trying to control my Tradfri lightbulbs with my freshly installed openHABian image. To connection through the binding seems to work but the bulb just doesn’t change its color/intensity.
What I did:
- Install a fresh openHABian image (v1.6.2) automatically
- Install Tradfri binding 3.0.0
- Import gateway and enter security code (status → ONLINE)
- Import bulb (automatic ID | status → ONLINE)
- Link color/color_temperature channel to a newly created item
When I change for example the color settings of a bulb the log (frontail) shows following entries:
but the color doesn’t change. Same color temperatur etc. When I change the color through the IKEA app the same entry shows and the color changes. Just not through openHAB.
What I tried:
- Deleting and newly inserting bulbs and/or gateway
- Renaming blubs in the IKEA App, deleting the item and insert again (according to this post)
- Reinstalling the binding
- Rebooting the raspberry pi
My IKEA gateway and lightbulbs are up to date (gw: 1.12.34 | bulbs: 1.3.013)
openHAB 3.0.0 on a Raspberry Pi 4 4GB
Gateway:
UID: tradfri:gateway:gwd44da439bd55
label: TRÅDFRI Gateway
thingTypeUID: tradfri:gateway
configuration:
host: 192.168.0.110
preSharedKey: 1EAUx2UNFedL1Qmw
port: 5684
identity: e06a6c6acd3442b28ef516bd304a5b73
Bulb:
UID: tradfri:0210:gwd44da439bd55:65539
label: Schlafzimmer
thingTypeUID: tradfri:0210
configuration:
bridgeUID: tradfri:gateway:gwd44da439bd55
I have made all the settings via the UI. Does anyone have/had a similar problem and knows what to do here?
Edit:
After a gateway reset it worked…
