Now I have an issue to Jsonpath for the respons from my KIA api, Json validates in some json validators but fails in jsonpath validators. Could anyone point me into the right direction for jsonpath or any other solution?
String Item whre I would like to catch value 130 for _ev_estimated_station_charge_duration_value=130, andI assuem the first string in ‘’ is a uid for that car and if I had multiple cars I also need a filter for just that uid.
EV_estimated_charging.postUpdate(transform("JSONPATH", "$.e238a624-1aa3-4d40-bed4-5fe3fcc9fde2.Vehicle._ev_estimated_station_charge_duration", json))
Response string or json or however to handle it
Kia json.txt (6.8 KB)
Samplecode from txt file
Item 'EV_estimated_charging' changed from {'e238a624-1aa3-4d40-bed4-5fe3fcc9fde2': Vehicle(id='e238a624-1aa3-4d40-bed4-5fe3fcc9fde2', name='E-SOUL', model='E-SOUL', registration_date='2021-02-27 11:28:11.022', year=None, VIN=None, key=None, _total_driving_distance=154, _total_driving_distance_value=154, _total_driving_distance_unit='km', _odometer=21124.6, _odometer_value=21124.6, _odometer_unit='km', car_battery_percentage=99, engine_is_running=False, last_updated_at=datetime.datetime(2022, 9, 7, 18, 5, 40, tzinfo=tzfile('/usr/share/zoneinfo/Europe/Berlin')), smart_key_battery_warning_is_on=None, washer_fluid_warning_is_on=None, brake_fluid_warning_is_on=None, _air_temperature='02H', _air_temperature_value='02H', _air_temperature_unit='°C', air_control_is_on=False, defrost_is_on=False, steering_wheel_heater_is_on=0, back_window_heater_is_on=0, side_mirror_heater_is_on=None, front_left_seat_status=None, front_right_seat_status=None, rear_left_seat_status=None, rear_right_seat_status=None, is_locked=False, front_left_door_is_open=0, front_right_door_is_open=0, back_left_door_is_open=0, back_right_door_is_open=0, trunk_is_open=False, hood_is_open=None, tire_pressure_all_warning_is_on=None, tire_pressure_rear_left_warning_is_on=None, tire_pressure_front_left_warning_is_on=None, tire_pressure_front_right_warning_is_on=None, tire_pressure_rear_right_warning_is_on=None, _next_service_distance=None, _next_service_distance_value=None, _next_service_distance_unit=None, _last_service_distance=None, _last_service_distance_value=None, _last_service_distance_unit=None, _location_latitude=58.541603, _location_longitude=15.059267, _location_last_set_time=datetime.datetime(2022, 9, 7, 20, 5, 7, tzinfo=tzfile('/usr/share/zoneinfo/Europe/Berlin')), ev_battery_percentage=58, ev_battery_is_charging=False, ev_battery_is_plugged_in=0, _ev_driving_distance=154, _ev_driving_distance_value=154, _ev_driving_distance_unit='km', _ev_estimated_current_charge_duration=0, _ev_estimated_current_charge_duration_value=0, _ev_estimated_current_charge_duration_unit='m', _ev_estimated_fast_charge_duration=74, _ev_estimated_fast_charge_duration_value=74, _ev_estimated_fast_charge_duration_unit='m', _ev_estimated_portable_charge_duration=600, _ev_estimated_portable_charge_duration_value=600, _ev_estimated_portable_charge_duration_unit='m', _ev_estimated_station_charge_duration=130, _ev_estimated_station_charge_duration_value=130, _ev_estimated_station_charge_duration_unit='m', _ev_charge_limits=EvChargeLimits(ac=0, dc=0), _fuel_driving_distance=None, _fuel_driving_distance_value=None, _fuel_driving_distance_unit=None, fuel_level=None, fuel_l
