How can I transform an empty string to something different using a map-file?
The map-file looks like, but doesn’t work: ’’=undefiniert =undefiniert
Logfile shows following error: Could not transform ‘’ with the file ‘anaus.map’ : Target value not found in map for ‘’
hmm. How do you get a empty string in the first place? Usually there is “NULL” or “UNDEF”, which works in map-transformation. You could try writing a rule changing ‘’ to UNDEF or something - or working on not having an empty string somehow…
