Transform Exec python output
i have a water-heater that i can interact with from a python script.
i have setup a thing as below
Thing exec:command:SwitcherAll [command="sudo python /etc/openhab2/scripts/Switcher-V2-Python/switcher.py 2", interval=60, timeout=5,autorun=false]
The full output is
2019-10-27 12:07:13.109 [vent.ItemStateChangedEvent] - Command_Output changed from NULL to =========================================================
                + Switcher V2 Python                                    +
                + Reverse Engineering and Coding By:                    +
                + Aviad Golan (@AviadGolan) and Shai Rod (@NightRang3r) +
[*] Sending Login Packet to Switcher...
[+] Received SessionID: 283a814f
[*] Getting Switcher state...
[+] Device Name: Switcher Boiler 09E1
[+] Device is ON
[+] Electric Current is: 11.6(A)
[+] Power consumption is: 2556(W)
[+] Device is configured to auto shutdown in: 2:00 hour(s)
[*] Auto shutdown device in: 1:52:59
[+] Done!
2019-10-27 12:08:26.215 [vent.ItemStateChangedEvent] - mqtt_sensor_motion17 changed from ON to OFF
i want to retrieve:
  1. Device is “STATUS”
  2. Electric Current is: 11.6(A)
  3. Power consumption is: 2556(W)
i have create 3 things as below
Thing exec:command:SwitcherDeviceStatus		[command="sudo python /etc/openhab2/scripts/Switcher-V2-Python/switcher.py 2", interval=60, timeout=5,autorun=false, transform="REGEX(.*Device is (.*) [+] Electric.*)"]
Thing exec:command:SwitcherDeviceElectric	[command="sudo python /etc/openhab2/scripts/Switcher-V2-Python/switcher.py 2", interval=60, timeout=5,autorun=false, transform="REGEX(.*Electric Current is: (.*)(A).*)"]
Thing exec:command:SwitcherDevicePower 		[command="sudo python /etc/openhab2/scripts/Switcher-V2-Python/switcher.py 2", interval=60, timeout=5,autorun=false, transform="REGEX(.*Power consumption is: (.*)(W).*)"]
Unfortunately the ouputs are empty.
I am missing something in my transform (which is well installed)
Thanks in advance
Your idea will run the script (and maybe its communications) three times.
If you want to analyze a single script output into three Items, you might want to do it in a rule (running the script once)
Right point
How can I extract sub text from a rule?
Trigger the rule from an update to your ‘source’ text Item, then apply your transforms in the rule to generate postUpdates for your target Items.
I know little about getting the regex right, though.
Thanks For your help
i am working only with only one Thing Exec and trying to manipulate it from the rule
i am close but i am retrieving
for Electric Current is: 11.5(A)=>5
for Power consumption is: 2535(W)=> 5
for Device is ON =>ON
is my transform regex correct ? ```
   SwitcherPowerConsumption = transform("REGEX", ".*(\\d).*", SwitcherPowerConsumption.toString)
you can find below the rule
rule "Command_Output "
   Item   Command_Output changed
val SwitcherStatus = 	Command_Output.state.toString.split('---').get(5)
val SwitcherElectric = 	Command_Output.state.toString.split('---').get(6)
val SwitcherPowerConsumption = 	Command_Output.state.toString.split('---').get(7)
        logInfo("SwitcherStatus", "---"+ SwitcherStatus)
        SwitcherStatus = transform("REGEX", "Device is (.*)", SwitcherStatus.toString)
        Switcher.postUpdate(SwitcherStatus)
        logInfo("SwitcherStatus", "---"+ SwitcherStatus +"---")
        logInfo("SwitcherElectric","---"+  SwitcherElectric+"---")
        SwitcherElectric = transform("REGEX",".*(\\d).*", SwitcherElectric.toString)
        NumberSwitcherElectric.postUpdate(SwitcherElectric)
        logInfo("SwitcherPowerConsumption", "---"+ SwitcherPowerConsumption)
        logInfo("SwitcherPowerConsumption    ", "---"+ SwitcherPowerConsumption   +"---")
        NumberSwitcherPowerConsumption.postUpdate(SwitcherPowerConsumption)
Logs
   2019-10-28 12:23:36.130 [vent.ItemStateChangedEvent] - Command_Output changed from --- Sending Login Packet to Switcher...
--- Received SessionID: 1097824f
--- Getting Switcher state...
--- Device Name: Switcher Boiler 09E1
--- Device is OFF
--- Electric Current is: 0.0(A)
--- Power consumption is: 0(W)
--- Device is configured to auto shutdown in: 2:00 hour(s)
--- Done! to
--- Received SessionID: df97824f
--- Device is ON
--- Electric Current is: 11.5(A)
--- Power consumption is: 2535(W)
--- Auto shutdown device in: 1:59:25
--- Done!
2019-10-28 12:23:36.197 [INFO ] [marthome.model.script.SwitcherStatus] - --- Device is ON
2019-10-28 12:23:36.215 [INFO ] [marthome.model.script.SwitcherStatus] - ---ON---
2019-10-28 12:23:36.223 [INFO ] [rthome.model.script.SwitcherElectric] - --- Electric Current is: 11.5(A)
---==> /var/log/openhab2/events.log <==
2019-10-28 12:23:36.243 [vent.ItemStateChangedEvent] - NumberSwitcherElectric changed from 0 to 5
2019-10-28 12:23:36.245 [INFO ] [rthome.model.script.SwitcherElectric] - ---5---
2019-10-28 12:23:36.252 [INFO ] [odel.script.SwitcherPowerConsumption] - --- Power consumption is: 2535(W)
2019-10-28 12:23:36.262 [INFO ] [.script.SwitcherPowerConsumption    ] - ---5---
2019-10-28 12:23:36.275 [vent.ItemStateChangedEvent] - NumberSwitcherPowerConsumption changed from 0 to 5
try to replace the Current regex from".*(\\d).*" to ".*(\\d{1,2}(.)\\d).*"
and the Power to ".*(\\d{1,4}).*"
BTW, where can get the py script?
(edit) found it: GitHub - NightRang3r/Switcher-V2-Python: This script will allow you to completely control the Switcher V2 device on your local network http://www.switcher.co.il/
I wish there was something similar to this in OH:https://www.youtube.com/watch?v=_ZENb42xPXk
There is a non-regex problem in your rule, declaring val and later trying to modify it. Use var
I have modified the rule to correctly get the values but still unable to parse the regex correctly to get the values out. Could anyone please suggest how to resolve it?
Rule:
rule "Switcher Output"
Item   Switcher_Command_Output changed
val SwitcherStatus = Switcher_Command_Output.state.toString.split('[+]').get(9)
val SwitcherCurrent = Switcher_Command_Output.state.toString.split('[+]').get(10)
val SwitcherPowerConsumption = Switcher_Command_Output.state.toString.split('[+]').get(11)
    var SwitcherStatusVar = transform("REGEX", "Device is (.*)", SwitcherStatus.toString)
    SwitchSwitcherStatus.postUpdate(SwitcherStatusVar)
    logInfo("SwitcherCurrent","---"+  SwitcherCurrent+"---")
    var SwitcherCurrentVar = transform("REGEX",".*(\\d(.)\\d).*", SwitcherCurrent.toString)
    NumberSwitcherCurrent.postUpdate(SwitcherCurrentVar)
    var SwitcherPowerConsumptionVar = transform("REGEX", ".*(\\d).*", SwitcherPowerConsumption.toString)
    NumberSwitcherPowerConsumption.postUpdate(SwitcherPowerConsumptionVar)
Log:
[+] Done! to =========================================================
[+] Received SessionID: 00000000
[+] Device Name: Switcher Touch
[+] Device is ON
[+] Electric Current is: 11.1(A)
[+] Power consumption is: 2446(W)
[+] Device is configured to auto shutdown in: 2:59 hour(s)
[*] Auto shutdown device in: 2:58:47
[+] Done!
2019-10-29 01:15:48.280 [vent.ItemStateChangedEvent] - System_CPU_Uptime changed from 11520.1 to 11522.1
2019-10-29 01:15:48.805 [INFO ] [marthome.model.script.SwitcherStatus] - ---] Device is ON
2019-10-29 01:15:48.817 [vent.ItemStateChangedEvent] - SwitchSwitcherStatus changed from NULL to
2019-10-29 01:15:48.820 [INFO ] [arthome.model.script.SwitcherCurrent] - ---] Electric Current is: 11.1(A)
2019-10-29 01:15:48.831 [vent.ItemStateChangedEvent] - NumberSwitcherCurrent changed from 0.0 to 1.1
2019-10-29 01:15:48.836 [INFO ] [odel.script.SwitcherPowerConsumption] - ---] Power consumption is: 2446(W)
2019-10-29 01:15:48.849 [vent.ItemStateChangedEvent] - NumberSwitcherPowerConsumption changed from 0 to 6
2019-10-29 01:21:04.328 [vent.ItemStateChangedEvent] - Switcher_Command_Output changed from =========================================================
[*] Sending Login Packet to Switcher…
[*] Getting Switcher state…
[+] Device is ON
[+] Electric Current is: 11.0(A)
[+] Power consumption is: 2417(W)
[*] Auto shutdown device in: 2:54:34
[+] Device is ON
[+] Electric Current is: 11.2(A)
[+] Power consumption is: 2463(W)
[*] Auto shutdown device in: 2:53:31
[+] Done!
2019-10-29 01:21:04.349 [INFO ] [marthome.model.script.SwitcherStatus] - —] Device is ON
2019-10-29 01:21:04.366 [INFO ] [arthome.model.script.SwitcherCurrent] - —] Electric Current is: 11.2(A)
2019-10-29 01:21:04.380 [INFO ] [odel.script.SwitcherPowerConsumption] - —] Power consumption is: 2463(W)
2019-10-29 01:21:04.385 [vent.ItemStateChangedEvent] - NumberSwitcherCurrent changed from 1.0 to 1.2
2019-10-29 01:21:04.398 [vent.ItemStateChangedEvent] - NumberSwitcherPowerConsumption changed from 7 to 3
In OH, the regular expression must match the entire string.
".*Device is (.*)\n.*"
Hi Rich,
My experience in software is lame and I am learning as I go here.
Could you please show me how to format the rule correctly in order to parse the 3 strings correctly?
Thank you.
i succeed as below
i have updated the script to get the output with this prefix
"— "for the split
the python script updated can be downloaded from https://paste.ofcode.org/WuUY8i8ZTQrtugs2wV7nxL
	val SwitcherStatus = 	Command_Output.state.toString.split('--- ').get(5).trim
	val SwitcherElectric = 	Command_Output.state.toString.split('--- ').get(6).trim
	val SwitcherPowerConsumption = 	Command_Output.state.toString.split('--- ').get(7).trim
	SwitcherElectric = transform("REGEX","Electric Current is: (.*)A", SwitcherElectric.toString)
	logInfo("SwitcherPowerConsumption", "---"+ SwitcherPowerConsumption+  "---")
	SwitcherPowerConsumption = transform("REGEX", "Power consumption is: (.*)W", SwitcherPowerConsumption.toString)
Update your regular expressions to match against the entire String returned by the script, as I demonstrated in my previous reply.
Thanks it works
