I finally managed to control my Arcam Solo Movie (amplifier with BD player) with openHAB 2.3 on Raspberry Pi 3 (openHABian) via TCP binding and would kindly ask you for your help!
For example I can successfully increase the volume via UP command but I am not able to read the response correctly
I added the following to the tcp.cfg
# Update the status of Items using the response received from the remote end (if the
# remote end sends replies to commands)
updatewithresponse=true
# Used character set
charset=ASCII
Here is the corresponding the Volume item:
Rollershutter VolumeHCpm "Lautstärke" <soundvolume> (LivingDining, gHomecinema) {tcp=">[UP:192.168.7.39:50000:'MAP(arcam.map)'], >[DOWN:192.168.7.39:50000:'MAP(arcam.map)'], >[STOP:192.168.7.39:50000:'MAP(arcam.map)']"}
In the arcam.map file I have:
UP=\u0021\u0001\u0008\u0002\u0010\u0010\u000D
\u0021\u0001\u0008\u0000\u0002\u0010\u0010\u000D=UP
The documentaion from Arcam tells me how the response should look like
Command:
STR ZONE CC DL Data 1 Data 2 ETR
0x21 0x01 0x08 0x02 0x10 0x10 0x0D
Response
STR ZONE CC AC DL Data 1 Data 2 ETR
0x21 0x01 0x08 0x00 0x02 0x10 0x10 0x0D
The outgoing transformation works perfectly, but the incoming is unfortunately not working
Here is my log file:
2018-06-07 23:37:13.867 [ome.event.ItemCommandEvent] - Item ‘VolumeHCpm’ received command UP
2018-06-07 23:37:13.874 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is '!
2018-06-07 23:37:13.995 [DEBUG] [ing.tcp.AbstractSocketChannelBinding] - Picked WriteBufferElement [Channel=Channel [item=VolumeHCpm, command=UP, direction=OUT, remote=/192.168.7.39:50000, buffer=, isBlocking=false, isReconnecting=true, channel=/192.168.7.253:43428::/192.168.7.39:50000, host=192.168.7.39, port=50000], buffer=!
, isblocking=false] from the queue
2018-06-07 23:37:13.998 [DEBUG] [ing.tcp.AbstractSocketChannelBinding] - Sending !
for the outbound channel /192.168.7.253:43428->/192.168.7.39:50000
2018-06-07 23:37:14.252 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.253 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.256 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input ! to match command OFF on item Home_cinema
2018-06-07 23:37:14.260 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.262 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.264 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input ! to match command ON on item Home_cinema
2018-06-07 23:37:14.267 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.269 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.273 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.275 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.281 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.283 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.287 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.291 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.293 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input ! to match command STOP on item VolumeHCpm
2018-06-07 23:37:14.298 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.300 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.304 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input ! to match command UP on item VolumeHCpm
2018-06-07 23:37:14.309 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.312 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.317 [WARN ] [ing.tcp.protocol.internal.TCPBinding] - Cannot parse input ! to match command DOWN on item VolumeHCpm
2018-06-07 23:37:14.322 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.325 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
2018-06-07 23:37:14.336 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘!’ with the file ‘arcam.map’ : Target value not found in map for ‘!’
2018-06-07 23:37:14.339 [DEBUG] [ing.tcp.protocol.internal.TCPBinding] - transformed response is ‘’
Could you please tell me, how this could work and what do I have to change?
Thank you very much for your support!
Kind regards,
picmac
