Hi there
I use (some) rtl_433 dongles to receive wireless-sensors. the mqtt-connection is ok, but I dont get things sorted with the values update in the items.
Item: Number Bresser5in1Temp "Aussentemperatur [%.2f °C]" (MMOG) { mqtt="<[broker:sensor/rtl433:state:JSONPATH($.temperature_C):.*\"model\"\\:Bresser-5in1,.*]"}
2019-04-30 12:40:40.254 [vent.ItemStateChangedEvent] - JSONTEST_Jsontest changed from {“time” : “2019-04-30 12:40:37.134333”, “protocol” : 76, “brand” : “LaCrosse”, “model” : “LaCrosse-TX29IT”, “id” : 18, “battery_ok” : 1, “newbattery” : 0, “temperature_C” : 12.100, “humidity” : 125, “mic” : “CRC”, “mod” : “FSK”, “freq1” : 868.325, “freq2” : 868.103, “rssi” : -11.671, “snr” : 16.855, “noise” : -28.527} to {“time” : “2019-04-30 12:40:40.066966”, “protocol” : 119, “model” : “Bresser-5in1”, “id” : 107, “temperature_C” : 9.900, “humidity” : 86, “wind_max_m_s” : 1.400, “wind_avg_m_s” : 2.000, “wind_dir_deg” : 90.000, “rain_mm” : 62.000, “mic” : “CHECKSUM”, “mod” : “FSK”, “freq1” : 868.336, “freq2” : 868.065, “rssi” : -0.125, “snr” : 30.258, “noise” : -30.383}
JSONPATH and REGEX-mappings are installed
any ideas?
regards
peter
