Transform() not defined in jsscript
OH 5.0 v 4464
str_url = "http://192.168.1.72/v1.0/bridge?"+ api_token;
var str_REST = actions.HTTP.sendHttpGetRequest(str_url, str_auth , 1000);
items.TedeeBridgeStatus.postUpdate(str_REST);
var newValue = transform("JSONPATH","$.SSID",str_REST);
items.TedeeBrigeSsid.postUpdate(newValue);
I get this error , did I missed to install something? I want to seperate SSID data from json object.
2025-01-12 10:54:33.852 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'tedee' failed: ReferenceError: "transform" is not defined in <eval> at line number 18 at column number 16
Transformation actions: JavaScript Scripting - Automation | openHAB
