i am trying to use map file where i want
0=OFF
1-10 = ON
how can i make it work ? mapping range of numbers to one string value… I tried SCALE also but didnt work.
0=OFF
1-10 = ON
So far i tried the following
// Sitemap
String Lamp1 "Lamp Light is [SCALE(range.scale):%s]"
[0] = OFF
[1-10] = ON
// alternate scale.map
[0,0] = OFF
[1-10] = ON
none worked so far …
What about using JS ?
I did not test it, but something like:
(function(i) {
var result = "undefined"
var int num = parseInt(i)
if (num == 0) result = "OFF"
if (num >= 1 && num <= 10) result = "ON"
return result;
})(input)
@gdhiraj Have you been able to get this to work? I am experiencing similar issues. According to the docs, you should use ..
as a separator, but that doesn’t work either for me.
[0..0] = OFF
[1..10] = ON
