spy0r
(Stefan)
1
Hi there,
if i have a mapping/transformation file, i use the following syntax:
originalValue1=newValue1
originalValue2=newValue2
undefinded=unknown
-=unknown
here is my question:
Is there an option for “anything else”? Undefined seems only to be the undefined state, but not a undefined “mapping”.
Thanks a lot!
Stefan
Marty56
(Martin)
2
The workaround I am using is to check on Null string after the mapping in a rule.
something like
birthday = transform(“MAP”, “Geburtstage.map”,searchday)
if (birthday = “”) then birthday = “nothing found”
spy0r
(Stefan)
3
if you just want to check if the string is empty you can use the mapping file itself with the line:
=nothing found
but i think the “anything else” path can only be solved within a rule, so thanks anyway.
edit:
i think i got your post wrong, you check the mapping file within the rule - that’s something i should try - thanks
