Transformation of Huawei Inverter Status
I am running OH 4.3.5 on a raspberry pi 5.
I read the values from the Huawei Inverter based on this Topic.
It used to work fine on OH 3, but now I do get the following errors:
2025-06-29 17:40:39.658 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '512.0' on item 'Device_status' with pattern 'MAP(inverter_device_status.map):%s': Transformation service of type 'MAP' is not available.
2025-07-01 22:25:57.773 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '40960.0' on item 'Device_status' with pattern 'MAP(inverter_device_status.map):%s': Transformation service of type 'MAP' is not available.
This is my Thing:
Bridge modbus:tcp:localhostTCP [ host="192.168.192.71", port=502, id=1 , rtuEncoded=false, timeBetweenTransactionsMillis=10000, connectMaxTries=2, afterConnectionDelayMillis=10000]
        Bridge poller slave105holding [ start=32064, length=31, refresh=1000, type="holding" ]
                Thing data Device_status                [ readStart="32089", readValueType="uint16", updateUnchangedValuesEveryMillis="5000000" ]
This is my Item:
Number    Device_status                      "Umrichter Status[MAP(inverter_device_status.map):%s]"    <settings>       (gSolar)               {channel="modbus:data:localhostTCP:slave105holding:Device_status:number"}
This is the mapping (inverter_device_status.map):
NULL=undefined
0=Initializing
1=Detecting ISO
2=Detecting irradiation
3=Grid detecting
256=Starting
512=On grid
513=On grid Power limit
514=On grid self derating
768=Shutdown fault
769=Shutdown command
770=Shutdown OVGR
771=Shutdown communication disconnected
772=Shutdown power limit
773=Shutdown start manually
774=Shutdown DC switch OFF
1025=Grid dispatch cos(Phi)-P curve
1026=Grid dispatch Q-U curve
40960=No irradiation
1280=Spot-check
1281=Spot-checking
1536=Inspecting
1792=AFCI self-check
2048=I V scanning
2304=DC input detection
0.0=Initializing
1.0=Detecting ISO
2.0=Detecting irradiation
3.0=Grid detecting
256.0=Starting
512.0=On grid
513.0=On grid Power limit
514.0=On grid self derating
768.0=Shutdown fault
769.0=Shutdown command
770.0=Shutdown OVGR
771.0=Shutdown communication disconnected
772.0=Shutdown power limit
773.0=Shutdown start manually
774.0=Shutdown DC switch OFF
1025.0=Grid dispatch cos(Phi)-P curve
1026.0=Grid dispatch Q-U curve
40960.0=No irradiation
1280.0=Spot-check
1281.0=Spot-checking
1536.0=Inspecting
1792.0=AFCI self-check
2048.0=I V scanning
2304.0=DC input detection
I do not understand why the Error occurs. Both values (40960.0 and 512.0) are in the mappings file.
Can anybody help me on this?
Did you install the Map transformation service?
No, it was not installed. Now I installed it.
Problem solved, thank you.
