This shouldn’t be the reason, but try to apply the transformation in your *.items file entry
I haven’t used xforms in sitemaps. Not sure if they work there (I see no reason why not)
by the way, sometimes I get the same for the MAP xformation
A simple restart of the OH2 service (after the first startup following an upgrade) solves this one.
Yes I have same problem, scale transformation doesn’t work anymore
I have been tied up with other things before realising that. @maintainers, is that eclipse or OH to report to?
@vzorglub: GitHub search will lead you to ESH (and btw, for core functionality it’s nearly always ESH)
Edit: There was a bigger refactoring on the transformation service 5 days ago (PR #5697). Maybe it’s caused by this one. So when you ping triller-telekom in your issue, you might get help a bit faster
