Hey,
I’m trying to bring values from velux ( Connecting Velux Active KIX 300 ) into openhab without learning all the osgi addon writing. My idea was to have a program (some go binary using swagger definition to call the API) which produces a json file. Then read this via the exec binding and transform it into Items.
That all works but I can only produce a String - not a Number
// what I want
Number:Temperature VeluxBedroomTemperature
"Schlafzimmer Temperatur [%.1f %C]"
<temperature>
(Bedroom, gTemperature)
{channel="exec:command:velux-temperature-bedroom:output", alexa="CurrentTemperature"}
// what works
String VeluxBedroomTemperature2
"Schlafzimmer Temperatur 2"
(Bedroom)
{channel="exec:command:velux-temperature-bedroom:output"}
Things I tried:
// one thing per input value with JSONPATH (that would be nice)
Thing exec:command:velux-co2-bedroom [command="cat /openhab/conf/velux-state.json", transform="JSONPATH($.Co2.Bedroom)", interval=30]
Thing exec:command:velux-temperature-bedroom [command="cat /openhab/conf/velux-state.json", transform="JSONPATH($.Temperature.Bedroom)", interval=30]
// reading the full state into one output and splitting in Item
Thing exec:command:velux [command="cat /openhab/conf/velux-state.json", interval=30]
// transforming using JS
Thing exec:command:velux-temp-bedroom [command="cat /openhab/conf/velux-state.json", transform="JS(jsonextract.js)", autorun=true]
Items I tried
String TestOutput1a "temp 1a" (Bedroom) {channel="exec:command:velux-temp-bedroom:output"}
Number TestOutput1b "temp 1b" (Bedroom) {channel="exec:command:velux-temp-bedroom:output"}
String TestOutput2a "temp 2a [%s]" (Bedroom) {channel="exec:command:velux-temp-bedroom:output"}
Number TestOutput2b "temp 2b [%s]" (Bedroom) {channel="exec:command:velux-temp-bedroom:output"}
String TestOutput3a "temp 3a" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JSONPATH", function="JSONPATH($.Temperature.Bedroom):%s"]}
Number TestOutput3b "temp 3b" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JSONPATH", function="JSONPATH($.Temperature.Bedroom):%s"]}
String TestOutput4a "temp 4a [JSONPATH($.Temperature.Bedroom):%s]" (Bedroom) {channel="exec:command:velux:output"}
Number TestOutput4b "temp 4b [JSONPATH($.Temperature.Bedroom):%d]" (Bedroom) {channel="exec:command:velux:output"}
String TestOutput5a "temp 5a" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JSONPATH", function="JSONPATH($.Temperature.Bedroom)"]}
Number TestOutput5b "temp 5b" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JSONPATH", function="JSONPATH($.Temperature.Bedroom)"]}
String TestOutput6a "temp 6a" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JS", function="jsonextract.js"]}
Number TestOutput6b "temp 6b" (Bedroom) {channel="exec:command:velux:output"[profile="transform:JS", function="jsonextract.js"]}
String TestOutput7a "temp 7a" (Bedroom) {channel="exec:command:velux-temperature-bedroom:output"}
Number TestOutput7b "temp 7b" (Bedroom) {channel="exec:command:velux-temperature-bedroom:output"}
jsonextract.js transform
(function(i) {
return parseInt(JSON.parse(i)["Temperature"]["Bedroom"])/10;
})(input)
Results
- All
Numberitems do not work
- 1a, 2a, 4a, 6a, 7a show the temperature but just as string (some of them of course don’t do the divide by 10 - but that’s expected)
- 5a and 3a just return the full json blob
- 3a, 4a and 5a contain the full json blob as state
I’m out of ideas. Sure I can create a rule which just converts the string state of one item into a Number state in another item but thats sounds super ugly.
I could try to use mqtt or http instead of exec - but that makes my program more complicated.
any Ideas?
