I started cleaning my system; try to figure out where my errors in my logfile come from.
First one and already I dont see my mistake
The error in my openhab-log:
2019-05-18 19:44:06.105 [INFO ] [g.knx.internal.dpt.KNXCoreTypeMapper] - Translator couldn't parse data for datapoint type '19.001' (KNXFormatException).
2019-05-18 19:44:06.105 [WARN ] [.internal.handler.DeviceThingHandler] - Ignoring KNX bus data: couldn't transform to any Type (destination='0/5/3', datapoint='command DP 0/5/3 'knx:device:KNXROUTER:iprouter_1_0_5', DPT id 19.001, low priority', data='0x770512D32C050080')
Next… the item in my knx.things:
Type datetime: datetime "Datum / Zeit" [ ga="19.001:<0/5/3" ]
The item comes from a MDT SCN-IP100.02 IP Router with E-Mail function. And it is a 8 byte Date/Time-Channel. And my ETS5 tells me it is 19.001 …
Inside my ETS5, if I try to read the item 0/5/3 the last data is p. ex. “77 05 12 D6 0E 05 00 80”
I don’t know much about OH2 since I am still on 1.8.3, but there DateTime is case-sensitive in CamelCase, not datetime.
Using DPT 19.001 did not work for me so far, therefore I am using separate fields for date & time with DPTs 10 and 11. If you found a solution, I would be also interested. Perhaps you can post the whole items definition?
