I’m using the main UI for my OH 5.1.1-1 installation.
Today I noticed, that when a cell, e.g. for an switch has active an trendline there, the highlight
color is not more working.
Is this as it should be?
So when trendline is set, the highlight color, which tells me if, e.g. the switch is set ON or OFF will not more work?
Yes, this is by design. Highlight color, trendline, and background components are all mutually exclusive configurations for the background of the cell. Placing any component in the background slot will override the other two and, as you have seen, having a trendline will take precedence over the use of the highlight color.
