hi guys,i need to write a rule for a night light .I want to light a lamp when my motion sensors triggered but only after 00:00 till 07:00.I cant find something so i can run this rule only between these hours…Any ideas?
There are other ways to do this, but this should work for you. Depending on your use case, you may not want the light to turn off at 7.
rule "Motion enabled between 0-7"
Item MotionItem changed
val Integer currentHour = now.getHourOfDay
logDebug("Rules", "test: currentHour={}",currentHour)
if ((0..7).contains(currentHour)) {
logDebug("Rules", "test: time is valid")
if (MotionItem.state == ON) {
// turn on light
else if (MotionItem.state == OFF) {
// turn off light
else {
logDebug("Rules", "test: time is not valid")
// if light is on, turn it off
Nice use of the set ( (0…7) ) operator. I always forget it there.
