sl4m
(Simon)
October 25, 2021, 2:18pm
1
Dear all,
i do have a datetime item of my next upcoming amazon echo alarm.
At the time of the alarm i want to trigger a sunrise light routine rule.
However, i dont know how to fire the rule at the value time of the datetime item (2021-10-26T06:15:00.000+0200).
Can someone give me a hint?
Do i need an additional rule for that?
Thank you a lot!
opus
(JĂŒrgen Baginski)
October 25, 2021, 2:29pm
2
I have a rule (ECMA) that triggers on each change of the next alarm in order to switch on my hotwater.
var logger = Java.type(âorg.slf4j.LoggerFactoryâ).getLogger(âorg.openhab.rule.â + ctx.ruleUID);
var ScriptExecution = Java.type(âorg.openhab.core.model.script.actions.ScriptExecutionâ);
var ZonedDateTime = Java.type(âjava.time.ZonedDateTimeâ);
var ZoneId = Java.type(âjava.time.ZoneIdâ);
var Instant=Java.type(âjava.time.Instantâ);
= (this.OPENHAB_CONF === undefined) ? java.lang.System.getenv(âOPENHAB_CONFâ) : this.OPENHAB_CONF;
load(OPENHAB_CONF+â/automation/lib/javascript/community/timeUtils.jsâ);
//var Exec = Java.type(âorg.openhab.core.model.script.actions.Execâ);
//var timerAlarm;
this.timerAlarm = (this.timerAlarm === undefined) ? null: this.timerAlarm;
var AlarmTime =items[âNaechsterAlarmâ];
//var WarmWasserSollTemperature = items[âWarmWasserSollTemperaturâ];
logger.info(âAlarmTime: {}â, AlarmTime);
try {
if (AlarmTime == UNDEF) {
if (this.timerAlarm != undefined) {
this.timerAlarm.cancel;
this.timerAlarm = undefined;
events.postUpdate(âNaechster_Alarmâ,UNDEF);
logger.info(âAll alarms are canceledâ);
} else {
var epoch = AlarmTime - 600000; // 10 Minuten vorher!!
logger.info("Scheduling Alarm for: "+ epoch);
var zdt=Instant.ofEpochMilli(epoch).atZone(ZoneId.systemDefault());
logger.info ("Converted AlarmTime: " + zdt);
events.postUpdate(âNaechster_Alarmâ,epoch);
if (timerAlarm !== null) {
logger.info(âReschedule Alarmâ);
this.timerAlarm.reschedule(zdt);
} else {
logger.info(âNew Alarmâ);
this.timerAlarm = ScriptExecution.createTimer(zdt, function(){
if (itemRegistry.getItem(âActiveModeâ).getState()!=âstandbyâ) {
if (itemRegistry.getItem(âDhwPumpsCirculationâ).getState()==âoffâ) {
var HTTP=Java.type(âorg.openhab.core.model.script.actions.HTTPâ);
var client_id = âcca64a97484842923a3d05b52325da8eâ;
var installationID=â137038â;
var gatewaySerial=â7571381700298105â;
var token=items[âViessmann_Tokenâ];
//logger.info (âtoken: {}â,token);
var headers = ;
headers[âAuthorizationâ] = âBearer â+ token;
var url =âhttps://api.viessmann.com/iot/v1/equipment/installations/ â+ installationID +â/gateways/â +gatewaySerial + â/devices/0/features/heating.dhw.oneTimeCharge/commands/activateâ;
//logger.info (âurl: {}â, url);
var returnvalue = HTTP.sendHttpPostRequest(url,âapplication/jsonâ, â{}â,headers,10*1000);
logger.info(âreturnvalue: {}â,returnvalue);
} else {
logger.info(âUmwĂ€lzpume ist an, also wird Warmwasser schon erzeugt!â);
} else {
logger.info(âAnlage ist im StandBy, Warmwasser wird nicht erzeugt!â);
logger.info(âAlarm is expiredâ);
this.timerAlarm = null;
catch(e) {
logger.info("Error observed : " + e.getMessage);
rlkoshak
(Rich Koshak)
October 25, 2021, 4:40pm
3
Yes you do need a rule for that. Trigger the rule when the DateTime Item changes and schedule a timer to run at the time in the DateTime Item.
If on a recent version (3.2 M3 or later) you can install just such a rule from the Marketplace.
[logo]
NOTE: This rule template is now deprecated. Please use the Time is <item> rule trigger. In the UI you can find that trigger under âTime Eventâ.
A rule template that will schedule the execution of another rule based on the state of a DateTime Item. This rule makes a good companion to use with the Android Appâs Alarm Item but it can be used with any DateTime Item.
The logger is named org.openhab.model.script.rules_tools.Alarm Clock
Configuration:
Parameter
Type
Required
Description
âŠ
You donât need to code this yourself.
