I have two LIFX bulbs that are on a physical switch in my home, and a third that is also in the same room on a different switch.
I am turning the two bulbs on with the physical switch like so:
- LIFX bulbs are off via OpenHab, physical switch is on
- Flip switch to off, LIFX bulbs lose power
- Flip switch to on, LIFX bulbs regain power and default to on
I’d like to capture the moment when the LIFX bulbs regain power, and setup a rule which switches the third bulb on.
I’ve tried tried monitoring item.lastUpdate and item.state, but neither seem to capture the moment of initialization.
Any suggestions?
