Dear all,
I have a Fibaro Motion Sensor that is showing a 1 or 0 respective of detected motion. I tried to set up a map that converts the 1 to “motion” or “Bewegung” in German. This did not work. However, I understood that some bindings do not support maps. Hence, I simply thought to set up a rule, i.e. if number item of MotionSensor changed to 1 then write to text item “motion detected” or “Bewegung” in German. I tried to play around with different woring in rules and I was looking in the forum but without success. The same issue exists with my KNX motion sensor.
My surely wrong rule looks like:
rule "Show Motion"
var motion = Item FibEye_Motion as Integer
when Item FibEye_Motion received update
if (motion = 1)
postUpdate(FibEye_Bewegung, "Bewegung")
if (motion = 0)
postUpdate(FibEye_Bewegung, "Keine Bewegung")
FibEye_Motion is my number item with the Z-Wave Binding that shows a 1 or 0. The FibEye_Bewegung is a String item that should show in text if there is motion.
Any ideas about how to deal with this?
Best regards,
Sebastian
