IIUC, @porst17 would like to have an additional channel for tint devices that can be used to set the manufacturer specific modes (Read: 3, Day: 1, Disco: 2, Night: 6, Fire: 4, Love: 5).
Unfortunately, my translation of
The six scene buttons [of the tint remote] send a Write Attributes to manufacturer-specific (0x121b) uint8 attribute 0x4005 of the Basic cluster. The value indicates the scene, although the order is a bit odd: Read: 3, Day: 1, Disco: 2, Night: 6, Fire: 4, Love: 5.
to a Karaf command for Fire mode (4) doesn’t work:
openhab> zigbee write 49940/1 0x0 0x4005 4 UNSIGNED_8_BIT_INTEGER
Attribute value write error: UNSUPPORTED_ATTRIBUTE
DUT is a tint Globe:
49940 C314 00158D00012E5426 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION EXTENDED_COLOR_LIGHT MLI tint-ExtendedColor
242 ZIGBEE_GREEN_POWER 0061
openhab> zigbee node 49940
IEEE Address : 00158D00012E5426
Network Address : 49940
Node Descriptor : NodeDescriptor [apsFlags=0, bufferSize=127, complexDescriptorAvailable=false, manufacturerCode=1029, logicalType=ROUTER, serverCapabilities=[], incomingTransferSize=90, outgoingTransferSize=90, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false, stackCompliance=22]
Power Descriptor : PowerDescriptor [currentPowerMode=RECEIVER_ON_IDLE, availablePowerSources=[MAINS], currentPowerSource=MAINS, powerLevel=FULL]
Associations : []
Endpoints :
1 : Profile ZIGBEE_HOME_AUTOMATION
: Device Type EXTENDED_COLOR_LIGHT
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> COLOR_CONTROL
-> 0x1000
242 : Profile ZIGBEE_GREEN_POWER
: Device Type 0061
<- GREEN_POWER
Neighbors :
Routes :
openhab> zigbee fingerprint 00158D00012E5426
|>| Node Descriptor
| |> Logical Type ROUTER
| |> MAC Capabilities [FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE]
| |> Stack Compliance 22
| |> Server Capabilities []
| |> Buffer Size 127
| |> Incoming Transfer Size 90
| |> Outgoing Transfer Size 90
|>| Power Descriptor
| |> Available Power Sources [MAINS]
| |> Current Power Source MAINS
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest SUCCESS
| |> IeeeAddressRequest SUCCESS
| |> ManagementLqiRequest SUCCESS
| |> ManagementRoutingRequest SUCCESS
|>| Basic Information
| |> Generic Device Class
| |> Generic Device Type
| |> Manufacturer Name MLI
| |> Model Indentifier tint-ExtendedColor
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version 1
| |> Software Build ID TDU50D01
| |> Hardware Version 1
| |> Zcl Version 2
| |> Stack Version 1
| |>| Endpoint 1
| | |> Profile 0104 ZIGBEE_HOME_AUTOMATION
| | |> Device Type 010D EXTENDED_COLOR_LIGHT
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> FAILURE
| | | |>| Cluster 0003 Identify
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> FAILURE
| | | |>| Cluster 0006 On/Off
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> FAILURE
| | | |>| Cluster 0008 Level Control
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> FAILURE
| | | |>| Cluster 0300 Color Control
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 1000
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| |>| Endpoint 242
| | |> Profile A1E0 ZIGBEE_GREEN_POWER
| | |> Device Type 0061
| | |> Device Version 0
openhab> zigbee endpoint 49940/1
Endpoint : 1
Device Profile : 0x0104, ZIGBEE_HOME_AUTOMATION
Device Type : 0x010D, EXTENDED_COLOR_LIGHT
Device Version : 1
Input Clusters : (Server)
0000 Basic
- APS Security disabled
S 0 r-- UNSIGNED_8_BIT_INTEGER ZCL Version Tue Jan 11 01:45:49 CET 2022 2
S 1 r-- UNSIGNED_8_BIT_INTEGER Application Version Tue Jan 11 01:45:48 CET 2022 1
S 2 r-- UNSIGNED_8_BIT_INTEGER Stack Version Tue Jan 11 01:45:49 CET 2022 1
S 3 r-- UNSIGNED_8_BIT_INTEGER HW Version Tue Jan 11 01:45:48 CET 2022 1
S 4 r-- CHARACTER_STRING Manufacturer Name Tue Jan 11 01:45:48 CET 2022 MLI
S 5 r-- CHARACTER_STRING Model Identifier Tue Jan 11 01:45:48 CET 2022 tint-ExtendedColor
S 6 r-- CHARACTER_STRING Date Code Tue Jan 11 01:45:48 CET 2022
S 7 r-- ENUMERATION_8_BIT Power Source
S 8 r-- ENUMERATION_8_BIT Generic Device Class
S 9 r-- ENUMERATION_8_BIT Generic Device Type
S 10 r-- CHARACTER_STRING Product Code
S 11 r-- CHARACTER_STRING Product URL
S 16 rw- CHARACTER_STRING Location Description
S 17 rw- ENUMERATION_8_BIT Physical Environment
S 18 rw- BOOLEAN Device Enabled
S 19 rw- BITMAP_8_BIT Alarm Mask
S 20 rw- BITMAP_8_BIT Disable Local Config
S 16384 r-- CHARACTER_STRING SW Build ID Tue Jan 11 01:45:48 CET 2022 TDU50D01
0003 Identify
S 0 rw- UNSIGNED_16_BIT_INTEGER Identify Time
0004 Groups
S 0 r-- BITMAP_8_BIT Name Support
0005 Scenes
S 0 r-- UNSIGNED_8_BIT_INTEGER Scene Count
S 1 r-- UNSIGNED_8_BIT_INTEGER Current Scene
S 2 r-- UNSIGNED_16_BIT_INTEGER Current Group
S 3 r-- BOOLEAN Scene Valid
S 4 r-- BITMAP_8_BIT Name Support
S 5 r-- IEEE_ADDRESS Last Configured By
0006 On/Off
S 0 r-s BOOLEAN On Off Tue Jan 11 01:21:04 CET 2022 true
S 16384 r-- BOOLEAN Global Scene Control
S 16385 rw- UNSIGNED_16_BIT_INTEGER On Time
S 16386 rw- UNSIGNED_16_BIT_INTEGER Off Wait Time
S 16387 rw- ENUMERATION_8_BIT Start Up On Off
0008 Level Control
S 0 r-s UNSIGNED_8_BIT_INTEGER Current Level Tue Jan 11 01:22:09 CET 2022 61
S 1 r-- UNSIGNED_16_BIT_INTEGER Remaining Time
S 2 r-- UNSIGNED_8_BIT_INTEGER Minimum Level
S 3 r-- UNSIGNED_8_BIT_INTEGER Maximum Level
S 4 r-s UNSIGNED_16_BIT_INTEGER Current Frequency
S 5 r-- UNSIGNED_16_BIT_INTEGER Minimum Frequency
S 6 r-- UNSIGNED_16_BIT_INTEGER Maximum Frequency
S 15 r-- BITMAP_8_BIT Options
S 16 rw- UNSIGNED_16_BIT_INTEGER On Off Transition Time
S 17 rw- UNSIGNED_8_BIT_INTEGER On Level
S 18 rw- UNSIGNED_16_BIT_INTEGER On Transition Time
S 19 rw- UNSIGNED_16_BIT_INTEGER Off Transition Time
S 20 rw- UNSIGNED_16_BIT_INTEGER Default Move Rate
S 16384 rw- UNSIGNED_8_BIT_INTEGER Start Up Current Level
0300 Color Control
S 0 r-s UNSIGNED_8_BIT_INTEGER Current Hue Tue Jan 11 01:22:12 CET 2022 1
S 1 r-s UNSIGNED_8_BIT_INTEGER Current Saturation Tue Jan 11 01:22:09 CET 2022 203
S 2 r-- UNSIGNED_16_BIT_INTEGER Remaining Time
S 3 r-s UNSIGNED_16_BIT_INTEGER Current X Tue Jan 11 01:48:13 CET 2022 34803
S 4 r-s UNSIGNED_16_BIT_INTEGER Current Y Tue Jan 11 01:48:23 CET 2022 21013
S 5 r-- ENUMERATION_8_BIT Drift Compensation
S 6 r-- CHARACTER_STRING Compensation Text
S 7 r-s UNSIGNED_16_BIT_INTEGER Color Temperature Tue Jan 11 01:22:12 CET 2022 509
S 8 r-- ENUMERATION_8_BIT Color Mode Tue Jan 11 01:20:04 CET 2022 0
S 16384 r-s UNSIGNED_16_BIT_INTEGER Enhanced Current Hue
S 16385 r-- ENUMERATION_8_BIT Enhanced Color Mode
S 16386 r-- UNSIGNED_8_BIT_INTEGER Color Loop Active
S 16387 r-- UNSIGNED_8_BIT_INTEGER Color Loop Direction
S 16388 r-- UNSIGNED_16_BIT_INTEGER Color Loop Time
S 16389 r-- UNSIGNED_16_BIT_INTEGER Color Loop Start Hue
S 16390 r-- UNSIGNED_16_BIT_INTEGER Color Loop Stored Hue
S 16394 r-- BITMAP_16_BIT Color Capabilities Tue Jan 11 01:16:05 CET 2022 31
S 16395 r-- UNSIGNED_16_BIT_INTEGER Color Temperature Min Tue Jan 11 01:16:57 CET 2022 153
S 16396 r-- UNSIGNED_16_BIT_INTEGER Color Temperature Max Tue Jan 11 01:16:57 CET 2022 555
1000
Output Clusters : (Client)
Groups Supported : 10
Groups Configured : 0
