I’ve recently migrated my openHAB installation from rpi3 to rpi4 and am now facing problems accessing openhab-share:
I’ve used the openhabian-config to create the samba shares and set the access passwords. The problem seems to be somehow related to ACLs (of which I do not have technical knowledge):
# ls -lisa /srv
total 32
56001 4 drwxr-xr-x 7 openhab openhabian 4096 Dec 16 12:27 .
2 4 drwxr-xr-x 21 root root 4096 Aug 20 12:48 ..
512125 4 drwxrwxr-x+ 2 openhab openhab 4096 Dec 15 18:01 openhab2-addons
513299 4 drwxrwxr-x+ 16 openhab openhab 4096 Dec 16 15:06 openhab2-conf
391763 4 drwxrwxr-x+ 2 openhab openhab 4096 Dec 27 02:01 openhab2-logs
512116 4 drwxrwxr-x+ 4 openhab openhab 4096 Dec 15 18:01 openhab2-sys
391765 4 drwxrwxr-x+ 13 openhab openhab 4096 Dec 16 19:53 openhab2-userdata
11242 4 -rw-rw-rw- 1 openhab openhabian 1430 Dec 15 18:50 README.txt
# mount | grep srv
/dev/mmcblk0p2 on /srv/openhab2-sys type ext4 (ro,relatime)
/dev/mmcblk0p2 on /srv/openhab2-addons type ext4 (ro,relatime)
/dev/mmcblk0p2 on /srv/openhab2-conf type ext4 (ro,relatime)
/dev/mmcblk0p2 on /srv/openhab2-logs type ext4 (ro,relatime)
/dev/mmcblk0p2 on /srv/openhab2-userdata type ext4 (ro,relatime)
I opened a github issue: https://github.com/openhab/openhabian/issues/1355
as I was able to reproduce it on a Debian 10 system.
In my installation I modifed the .mount files that are created from the template.
It seems to work as I get rw mounted shares after reboots.
I am new to github. Means that I created an account to raise that ticket.
I see a message that my account was flagged.
So it looks like items that are related to my account are hidden.
I just was contacting the github support to help to resovle this.
Once it is resolved I assume that the tickets will be visible.
I’ve checked the ticket, it is visible now, thank you!
Am I getting it right that this is a problem that can be fixed by adjusting the openhabian-config tool? If so, where can I find the template to adjust? I found such a file at /opt/openhabian/includes/srv_mount_template, is that right? Do I have to just re-run menu 13 after making the adjustments?
Thank you all, who contributed here and on GitHub
I had a similar problem with teh shared in ro mode, after a SD card got partially corrupted.
Using the Openhabian interface (13) was a very quick solution.
