I tried multiple times but couldn’t get it successfully added. When I opened up the jar file, I couldn’t find a ‘zd2105.xml’ file in there but when I checked the database online, it showed up:
In OH1, you don’t need a database entry to use a device, and it’s certainly not need for inclusion into the network. The database is only needed for configuration, and in this respect it looks like this device isn’t in the OH1 database and will need to be added.
OK. So, maybe this is a stupid question, but how do I use the device in this case? I have only ever used Habmin to include/configure my previous devices and, in this case, the association group does not get populated under Habmin so I cannot select my controller (Sigma Designs UZB) as a member, so I don’t get any notifications when the device status changes. I added these to the items file and I don’t see it coming up in the events.log when I trigger the device:
If you need to do configuration, then as I said earlier, the device will need to be added to the database. I will try to add it later this evening unless you fancy producing a PR for this…
