- Platform information:
- Hardware: x86
- OS: Docker in Kubernetes
- Java Runtime Environment: openhab/openhab:3.3.0
- openHAB version: 3.3
Hi, I’m looking for a bit of help working with groups within groups.I could code this all out with a lot of repetition with fixes group and item names but that is going to be a bit of a nightmare and not scale.
Theoretical
Want to get a group from main group then get the members of the sub group
Main group
Sub group 1 = ON
Switch 1 = ON
Switch 2 = OFF
Switch 3 = ON
etc
Sub Group 2 = ON
Switch 1 = ON
Switch 2 = ON
Switch 3 = ON
etc
Sub Group 3 = OFF
Switch 1 = OFF
Switch 2 = OFF
Switch 3 = OFF
etc
More sub groups……
Rule
- Get a sub group that is a member of the main group and = ON
- Do stuff (this needs to run in a specific order, and is not sortable by number or letter)
a. If switch 1 is ON then
b. Else if switch 2 is on then
c. etc - Get the next sub group that is ON
a. Etc. - Etc.
Actaul itesms and what I have so far… (you can probably see where this is going… there will be a start time for each ‘mode’, so need to check through with else if)
gRoomModeRoomEnable.members.filter[ i | i.state == ON ].forEach[ i |
logInfo("ROOM", i.toString)
Output
2022-10-24 09:55:31.121 [INFO ] [org.openhab.core.model.script.ROOM ] - gLivingRoomModeEnable (Type=GroupItem, BaseType=SwitchItem, Members=19, State=ON, Label=Living Room Mode Enable, Category=settings, Groups=[gRoomModeRoomEnable, gLivingRoomModeSettings])
2022-10-24 09:55:31.121 [INFO ] [org.openhab.core.model.script.ROOM ] - gDiningRoomModeEnable (Type=GroupItem, BaseType=SwitchItem, Members=19, State=ON, Label=Dining Room Mode Enable, Category=settings, Groups=[gRoomModeRoomEnable, gDiningRoomModeSettings])
First room
gLivingRoomModeEnable.members.filter[ i | i.state == ON ].forEach[ i |
Output
2022-10-24 09:57:10.925 [INFO ] [org.openhab.core.model.script.ROOM ] - livingRoomModeWeekdayEarlyEveningEnable (Type=SwitchItem, State=ON, Label=Living Room Enable Weekday Early Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gLivingRoomModeEnable, gLivingRoomModeWeekdayEarlyEvening])
2022-10-24 09:57:10.926 [INFO ] [org.openhab.core.model.script.ROOM ] - livingRoomModeWeekdayNightEnable (Type=SwitchItem, State=ON, Label=Living Room Enable Weekday Night Mode, Category=switch, Tags=[Switch, Scene], Groups=[gLivingRoomModeEnable, gLivingRoomModeNight])
Next room
gDiningRoomModeEnable.members.filter[ i | i.state == ON ].forEach[ i |
Output
2022-10-24 09:58:50.774 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEarlyMorningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Early Morning Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEarlyMorning])
2022-10-24 09:58:50.774 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayMorningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Morning Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayMorning])
2022-10-24 09:58:50.775 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayDaytimeEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Daytime Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayDaytime])
2022-10-24 09:58:50.775 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEarlyEveningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Early Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEarlyEvening])
2022-10-24 09:58:50.775 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEveningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEvening])
2022-10-24 09:58:50.776 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayNightEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Night Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeNight])
And all members of main group (just for info really)
gRoomModeRoomEnable.allMembers.filter[ i | i.state == ON ].forEach[ i |
Output
2022-10-24 10:00:00.789 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEveningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEvening])
2022-10-24 10:00:00.789 [INFO ] [org.openhab.core.model.script.ROOM ] - livingRoomModeWeekdayEarlyEveningEnable (Type=SwitchItem, State=ON, Label=Living Room Enable Weekday Early Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gLivingRoomModeEnable, gLivingRoomModeWeekdayEarlyEvening])
2022-10-24 10:00:00.789 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEarlyMorningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Early Morning Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEarlyMorning])
2022-10-24 10:00:00.790 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayDaytimeEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Daytime Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayDaytime])
2022-10-24 10:00:00.790 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayEarlyEveningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Early Evening Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayEarlyEvening])
2022-10-24 10:00:00.790 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayNightEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Night Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeNight])
2022-10-24 10:00:00.791 [INFO ] [org.openhab.core.model.script.ROOM ] - livingRoomModeWeekdayNightEnable (Type=SwitchItem, State=ON, Label=Living Room Enable Weekday Night Mode, Category=switch, Tags=[Switch, Scene], Groups=[gLivingRoomModeEnable, gLivingRoomModeNight])
2022-10-24 10:00:00.791 [INFO ] [org.openhab.core.model.script.ROOM ] - diningRoomModeWeekdayMorningEnable (Type=SwitchItem, State=ON, Label=Dining Room Enable Weekday Morning Mode, Category=switch, Tags=[Switch, Scene], Groups=[gDiningRoomModeEnable, gDiningRoomModeWeekdayMorning])
What I was thinking is
gRoomModeRoomEnable.members.forEach[ i | {
var groupName = i.name.toString
logInfo("GROUP", groupName)
var modes = groupName.members.filter[ i | i.state == ON ].map[ name ]
logInfo("ROOM", modes.toString)
// I can make the below work
//room = some code to remove the the prefix g and suffix ModeEnable = diningRoom
if(modes.contains(room + "ModeWeekdayNightEnable")) {
// check = "night"
logInfo("contains", "night")
else if(modes.contains(room + "ModeWeekdayDaytimeEnable")) {
// check = "daytime"
logInfo("contains", "day")
else if{
// etc. etc.
This works in seperate parts, but groupName.members.filter
isnt happy. I think it is porbably looking for a Group item called groupName
, rather than using the output of the gRoomModeRoomEnable.members.forEach
and I dont know how to achieve that. Any other ideas are welcome as this is by far the most complex rule I have created and the frst time really using members.
Thanks.
