Trying to get HTTP.sendHttpPutRequest to work in jython
From an old thread …
Old thread, so maybe this is solved elsewhere, but after a few hours of searching I give up:
I am trying to send a HTTP.sendHttpPutRequest from OH3 jython with json data and Authorization …
I’ve tried many iterations, but here is one:
    uri = "http://openhabian.local:8080/rest/things/zwave:device:0d28f614c7:node8/config"
    data = {
     'key': 'value',
    auth = {'Authorization' : 'Bearer <mytoken>'}
    content = {'content-type' : 'application/json'}
    HTTP.sendHttpPutRequest(uri, str(content),str(data),auth, 10000)
I get the following error:
2021-10-07 14:31:35.304 [WARN ] [s.impl.WebApplicationExceptionMapper] - javax.ws.rs.NotSupportedException: HTTP 415 Unsupported Media Type
Is there a simple example to follow?
My curl is working fine, so if I could just get the values into the right format that the HTTP requests wants it would work …
Well, I found the problem … in this case the “content” should just be the content as in ‘application/json’
So just saying:
content = ‘application/json’
Fixed it … :upside_down_face: :roll_eyes:
