Raspberry PI 4 Openhabian
openHAB 3.2.0.M4
I have a bunch of different models of Vstarcam that support ONVIF and trying to make things work.
- I have Trace enabled to watch the activity.
- I can connect to the camera (Thing shows ONLINE) … I used auto discovery … I changed the default “Poll Time” to 2000 (was getting timeouts at 1 sec)
- Tried getting an image via the URL (http://IP:8080/ipcamera/100057/ipcamera.jpg) but it doesn’t return a result. Log shows:
2022-07-10 16:07:48.065 [DEBUG] [amera.internal.servlet.CameraServlet] - GET:/ipcamera.jpg, received from 10.0.0.21
2022-07-10 16:07:48.083 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
2022-07-10 16:07:48.129 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
2022-07-10 16:07:53.099 [WARN ] [amera.internal.servlet.CameraServlet] - ipcamera.jpg was requested but there was no jpg in ram to send.
2022-07-10 16:07:53.115 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
2022-07-10 16:07:53.144 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
However, I can access the image using the http://10.0.0.54:38254/snapshot.cgi
Also, in my openHAB-userdata/ipcamera/100057
directory it is empty. (Not sure if that’s relevant)
- Tried getting an mpeg via the URL (http://10.0.0.23:8080/ipcamera/100057/ipcamera.mjpeg) … no luck. Log shows:
2022-07-10 16:16:56.644 [DEBUG] [amera.internal.servlet.CameraServlet] - GET:/ipcamera.mjpeg, received from 10.0.0.21
2022-07-10 16:16:56.656 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Starting ffmpeg with this command now:-rtsp_transport tcp -hide_banner -loglevel warning -i rtsp://admin:********@10.0.0.54:10554/tcp/av0_1 -q:v 5 -r 2 -vf scale=640:-2 -update 1 http://127.0.0.1:8080/ipcamera/100057/ipcamera.jpg
2022-07-10 16:16:58.012 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - rtsp://admin:********@10.0.0.54:10554/tcp/av0_1: Invalid data found when processing input
- Tried panning but get no activity … log shows:
2022-07-10 16:20:27.529 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:AbsoluteMove
2022-07-10 16:20:27.568 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tptz:AbsoluteMoveResponse></tptz:AbsoluteMoveResponse></s:Body></s:Envelope>
2022-07-10 16:20:27.018 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'onvifcamera100057_Pan' received command 80
2022-07-10 16:20:27.020 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'onvifcamera100057_Pan' predicted to become 80
2022-07-10 16:20:27.026 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'onvifcamera100057_Pan' changed from 0 to 80
- When I disable then enable the THING … the log shows:
2022-07-10 16:22:28.707 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Unsubscribe
2022-07-10 16:22:28.753 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><s:Fault><s:Code><s:Value>s:Receiver</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">Action Not Implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>
2022-07-10 16:22:28.695 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:100057' changed from ONLINE to UNINITIALIZED
2022-07-10 16:22:28.743 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:100057' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-07-10 16:22:30.770 [DEBUG] [amera.internal.onvif.OnvifConnection] - Eventloop is shutdown:true
2022-07-10 16:22:45.831 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2022-07-10 16:22:45.860 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>Manual</tt:DateTimeType><tt:DaylightSavings>false</tt:DaylightSavings><tt:TimeZone><tt:TZ>PST0PDT</tt:TZ></tt:TimeZone><tt:UTCDateTime><tt:Time><tt:Hour>23</tt:Hour><tt:Minute>22</tt:Minute><tt:Second>45</tt:Second></tt:Time><tt:Date><tt:Year>2022</tt:Year><tt:Month>7</tt:Month><tt:Day>10</tt:Day></tt:Date></tt:UTCDateTime></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.861 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2022-07-10 16:22:45.865 [DEBUG] [amera.internal.onvif.OnvifConnection] - Cameras UTC dateTime is:2022-7-10T23:22:45
2022-07-10 16:22:45.868 [DEBUG] [amera.internal.onvif.OnvifConnection] - Openhabs UTC dateTime is:2022-07-10T23:22:45.868Z
2022-07-10 16:22:45.890 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Device><tt:XAddr>http://10.0.0.54:10080/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:ZeroConfiguration>false</tt:ZeroConfiguration><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS></tt:Network><tt:System><tt:DiscoveryResolve>true</tt:DiscoveryResolve><tt:DiscoveryBye>false</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>true</tt:SystemBackup><tt:SystemLogging>true</tt:SystemLogging><tt:FirmwareUpgrade>true</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>42</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>20</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>10</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>0</tt:Minor></tt:SupportedVersions></tt:System><tt:IO><tt:InputConnectors>0</tt:InputConnectors><tt:RelayOutputs>0</tt:RelayOutputs></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken></tt:Security></tt:Device><tt:Events><tt:XAddr>http://10.0.0.54:10080/onvif/event_services</tt:XAddr><tt:WSSubscriptionPolicySupport>false</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>false</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://10.0.0.54:10080/onvif/image_services</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://10.0.0.54:10080/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>true</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>10</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:PTZ><tt:XAddr>http://10.0.0.54:10080/onvif/ptz_services</tt:XAddr></tt:PTZ></tds:Capabilities></tds:GetCapabilitiesResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.892 [DEBUG] [amera.internal.onvif.OnvifConnection] - deviceXAddr:/onvif/device_service
2022-07-10 16:22:45.893 [DEBUG] [amera.internal.onvif.OnvifConnection] - eventsXAddr:/onvif/event_services
2022-07-10 16:22:45.894 [DEBUG] [amera.internal.onvif.OnvifConnection] - mediaXAddr:/onvif/media_service
2022-07-10 16:22:45.895 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzXAddr:/onvif/ptz_services
2022-07-10 16:22:45.896 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetProfiles
2022-07-10 16:22:45.935 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><trt:GetProfilesResponse><trt:Profiles fixed="true" token="PROFILE_000"><tt:Name>PROFILE_000</tt:Name><tt:VideoSourceConfiguration token="V_SRC_000"><tt:Name>V_SRC_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:SourceToken>V_SRC_000</tt:SourceToken><tt:Bounds height="720" width="1280" y="0" x="0"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="A_SRC_000"><tt:Name>A_SRC_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>A_SRC_000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="V_ENC_000"><tt:Name>V_ENC_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>1280</tt:Width><tt:Height>720</tt:Height></tt:Resolution><tt:Quality>4</tt:Quality><tt:RateControl><tt:FrameRateLimit>25</tt:FrameRateLimit><tt:EncodingInterval>40</tt:EncodingInterval><tt:BitrateLimit>2048</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>100</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="A_ENC_000"><tt:Name>A_ENC_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>G711</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>8</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:PTZConfiguration token="PTZ_000"><tt:Name>PTZ_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:NodeToken>NODE_000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="0.5" y="0.5" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" /><tt:Zoom x="0.5" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" /></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration></trt:Profiles><trt:Profiles fixed="true" token="PROFILE_001"><tt:Name>PROFILE_001</tt:Name><tt:VideoSourceConfiguration token="V_SRC_001"><tt:Name>V_SRC_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:SourceToken>V_SRC_001</tt:SourceToken><tt:Bounds height="480" width="640" y="0" x="0"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="A_SRC_000"><tt:Name>A_SRC_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>A_SRC_000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="V_ENC_001"><tt:Name>V_ENC_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>480</tt:Height></tt:Resolution><tt:Quality>4</tt:Quality><tt:RateControl><tt:FrameRateLimit>25</tt:FrameRateLimit><tt:EncodingInterval>40</tt:EncodingInterval><tt:BitrateLimit>512</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>100</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="A_ENC_000"><tt:Name>A_ENC_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>G711</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>8</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:PTZConfiguration token="PTZ_000"><tt:Name>PTZ_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:NodeToken>NODE_000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="0.5" y="0.5" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" /><tt:Zoom x="0.5" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" /></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration></trt:Profiles></trt:GetProfilesResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.938 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:PROFILE_000
2022-07-10 16:22:45.939 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:PROFILE_001
2022-07-10 16:22:45.940 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSnapshotUri
2022-07-10 16:22:45.942 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStreamUri
2022-07-10 16:22:45.950 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetNodes
2022-07-10 16:22:45.953 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetEventProperties
2022-07-10 16:22:45.960 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetServiceCapabilities
2022-07-10 16:22:45.963 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://10.0.0.54:38254/snapshot.cgi</tt:Uri><tt:InvalidAfterConnect>false</tt:InvalidAfterConnect><tt:InvalidAfterReboot>false</tt:InvalidAfterReboot><tt:Timeout>PT5S</tt:Timeout></trt:MediaUri></trt:GetSnapshotUriResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.964 [DEBUG] [amera.internal.onvif.OnvifConnection] - GetSnapshotUri:/snapshot.cgi
2022-07-10 16:22:45.989 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Header><wsa:Action>http://www.onvif.org/ver20/ptz/wsdl/GetNodesResponse</wsa:Action></s:Header><s:Body><tptz:GetNodesResponse><tptz:PTZNode token="NODE_000" FixedHomePosition="false"><tt:Name>NODE_000</tt:Name><tt:SupportedPTZSpaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:SupportedPTZSpaces><tt:MaximumNumberOfPresets>100</tt:MaximumNumberOfPresets><tt:HomeSupported>true</tt:HomeSupported></tptz:PTZNode></tptz:GetNodesResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.990 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStatus
2022-07-10 16:22:45.993 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzNodeToken=NODE_000
2022-07-10 16:22:46.000 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurations
2022-07-10 16:22:46.001 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Header><wsa:Action>http://www.onvif.org/ver10/events/wsdl/EventPortType/GetEventPropertiesResponse</wsa:Action></s:Header><s:Body><tev:GetEventPropertiesResponse><tev:TopicNamespaceLocation>http://www.onvif.org/onvif/ver10/topics/topicns.xml</tev:TopicNamespaceLocation><wsnt:FixedTopicSet>true</wsnt:FixedTopicSet><wstop:TopicSet xmlns=""><tns1:RuleEngine><CellMotionDetector><Motion wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="VideoSourceConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="VideoAnalyticsConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="Rule" Type="xs:string"/></tt:Source><tt:Data><tt:SimpleItemDescription Name="IsMotion" Type="xs:boolean"/></tt:Data></tt:MessageDescription></Motion></CellMotionDetector></tns1:RuleEngine></wstop:TopicSet><wsnt:TopicExpressionDialect>http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet</wsnt:TopicExpressionDialect><wsnt:TopicExpressionDialect>http://docs.oasis-open.org/wsnt/t-1/TopicExpression/ConcreteSet</wsnt:TopicExpressionDialect><wsnt:TopicExpressionDialect>http://docs.oasis-open.org/wsn/t-1/TopicExpression/Concrete</wsnt:TopicExpressionDialect><tev:MessageContentFilterDialect>http://www.onvif.org/ver10/tev/messageContentFilter/ItemFilter</tev:MessageContentFilterDialect><tev:MessageContentSchemaLocation>http://www.onvif.org/onvif/ver10/schema/onvif.xsd</tev:MessageContentSchemaLocation></tev:GetEventPropertiesResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.003 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:CreatePullPointSubscription
2022-07-10 16:22:46.006 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Header><wsa:Action>http://www.onvif.org/ver10/events/wsdl/EventPortType/GetServiceCapabilitiesResponse</wsa:Action></s:Header><s:Body><tev:GetServiceCapabilitiesResponse><tev:Capabilities WSSubscriptionPolicySupport="false" WSPullPointSupport="false" WSPausableSubscriptionManagerInterfaceSupport="false" MaxNotificationProducers="10" MaxPullPoints="10" PersistentNotificationStorage="false" /></tev:GetServiceCapabilitiesResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.008 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://10.0.0.54:10554/tcp/av0_1</tt:Uri><tt:InvalidAfterConnect>false</tt:InvalidAfterConnect><tt:InvalidAfterReboot>false</tt:InvalidAfterReboot><tt:Timeout>PT60S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.009 [DEBUG] [amera.internal.onvif.OnvifConnection] - GetStreamUri:rtsp://10.0.0.54:10554/tcp/av0_1
2022-07-10 16:22:46.021 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:Position><tt:PanTilt x="0.0" y="0.0" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" /><tt:Zoom x="0.0" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" /></tt:Position><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>2022-07-10T23:22:45Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.022 [DEBUG] [amera.internal.onvif.OnvifConnection] - Processing new PTZ location now
2022-07-10 16:22:46.023 [DEBUG] [amera.internal.onvif.OnvifConnection] - Pan is updating to:50 and the cam value is 0.0
2022-07-10 16:22:46.024 [DEBUG] [amera.internal.onvif.OnvifConnection] - Tilt is updating to:50 and the cam value is 0.0
2022-07-10 16:22:46.024 [DEBUG] [amera.internal.onvif.OnvifConnection] - Zoom is updating to:0 and the cam value is 0.0
2022-07-10 16:22:46.030 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><s:Fault><s:Code><s:Value>s:Receiver</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">Action Not Implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>
2022-07-10 16:22:46.035 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="PTZ_000"><tt:Name>PTZ_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:NodeToken>NODE_000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="0.5" y="0.5" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" /><tt:Zoom x="0.5" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" /></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.037 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2022-07-10 16:22:46.040 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzConfigToken=PTZ_000
2022-07-10 16:22:46.041 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurationOptions
2022-07-10 16:22:46.073 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tptz:GetPresetsResponse></tptz:GetPresetsResponse></s:Body></s:Envelope>
2022-07-10 16:22:46.073 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" ><s:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.0</tt:Min><tt:Max>1.0</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:Spaces><tt:PTZTimeout><tt:Min>PT1S</tt:Min><tt:Max>PT60S</tt:Max></tt:PTZTimeout></tptz:PTZConfigurationOptions></tptz:GetConfigurationOptionsResponse></s:Body></s:Envelope>
2022-07-10 16:22:45.816 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:100057' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-07-10 16:22:49.858 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
2022-07-10 16:22:49.858 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:onvif:100057' changed from INITIALIZING to ONLINE
2022-07-10 16:22:50.958 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://10.0.0.54:38254/snapshot.cgi
Sorry for the huge log but not sure what is helpful info … so in summary, it appears that the binding is communication with the camera via ONVIF based on the XML responses but not getting any activity from the camera. FYI, I can use a generic OSX app to talk to the cameras via ONVIF and get video, audio and PTZ features.
As I said, I have multiple versions of these cameras, this particular one seemed to give the best results, none of them worked (i.e. got images or panning)
Ideas for me to try?
