EDIT: I’m a new user so can only put in 2 links. httx == http. Sorry!
I’m totally new to open hab (and pretty new to linux) so I’m struggling a little bit!
I followed the guide here https://github.com/openhab/openhab/wiki/Linux---OS-X and installed my plugins using apt-get as they suggested, but there is no /addins folder under /etc/OpenHab/ so I don’t know if it installed correctly!
Long and short of it the sitemap is showing my plex commands, and pressing the buttons is not working. I can’t see any errors in the logs I can find in /var/log/openhab so I’m at a bit of a loss.
I did add in the plex:username, plex:email and plex:authenticationToken settings into the openhab.cfg as per the suggestion in this forum post: Plex Binding on Plex Home setup (which should probably exist in the wiki httxs://github.com/openhab/openhab/wiki/Plex-Binding I’m guessing!)
Make sure you only have one plex binding jar file in the /usr/share/openhab/addons folder at any time. Look at your /var/log/openhab/openhab.log file for anything suspicious.
